Question about Canon Office Equipment & Supplies
Fuser film has split so looking for part number of fuser film or fuser assy of canon L100 fax machine
  • 1,219 Answers
FM2-3967-000 FIXING ***'Y FOR 120V, and
FM2-3968-000 FIXING ***'Y FOR 230V.
Best way is to replace whole unit, because of pressure, bushings,...
Posted on Jun 25, 2010
Canon code E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Oct 21, 2015 | Canon Office Equipment & Supplies
Hello every one, i have iR Canon 2420 copier, first time i have a problem on the fuser and i changed it with the new one. After that the machine copy correctly but the text copied will be erased easil
Dear
The fuser unit consiting of two pars
1-fixing film assy. (Heter unit)
2-fixing unit-(Complete set.)
if you have replaced new fixing film assy. in old fixing unit-this may be the result due to the pressure roller and it allied parts.
if you have replaced complete unit then check you toner and paper properties.
Thanks.
Dec 02, 2014 | Canon Office Equipment & Supplies
Blurred print of incoming and outgoing report
There are usually two things that can cause blurred printing.
1 The toner/drum needs changing.
2 The fuser assy is worn and not fusing the toner onto the paper correctly. This is easy to check. Does the print rub off the paper with your finger? If so then a new fuser is required. Also its possible a tooth on the gear that drives the fuser is broken. The fuser gear may have also worn down and its jumping on the gear that drives it.
Dec 20, 2013 | Canon LaserClass LC 8500 Plain Paper Fax
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
Solution to solve system Error E007 on IR 2016i copy machine
Was the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error.
error codad E007 First make sure fuser plastic not damage? Or not move the proper place? if damage fuser plastic Replace by new one if the fuser plastic not damage keep proper place.
fixing fuser film is worn out or broken remove the fixing unit ang check the fuser film if its worn out broken replace a new one .
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Canon CLC 1140 Copier
F-300 fax MURATEC
DA7A013A4X ASSY FUSER
May 14, 2010 | Muratec F-300 Fax
Fax is blured on the right side
It could be that the fuser film is faulty!It can also be the cartridge,i would suggest to try a new cartridge first if it is when u recieve faxes?Try putting in a old one to save u from buying a new one!If its still doing the same its the fuser film and you will have to replace it!Good Luck!
Apr 30, 2010 | Canon LaserClass LC 8500 Plain Paper Fax
E 000007-0000
This error is for the fuser assy. It indicates that the fuser film is not rotating and is most likely damaged. The fixing film assy will have to be replaced. The whole fuser should not need to be replaced just the part that gets hot. There will be no error reset required.
Oct 06, 2008 | Canon imageRUNNER 4570 Copier
Canon Error Eoo7
This error code indicates to the copier that the upper fixing film on the fuser assy is not rotating. Paper wrapped around the fixing film or the film itself is damaged may cause this. Unless you are very mechanically inclined , it will take the removal of the fixing assy and possibly the replacing of the fixing film assy. A tech would need to be called in to correct the problem. The fixing film is a replaceable item. Good luck.
Sep 26, 2007 | Canon imageRUNNER 8500 Copier
154 people viewed this question
old marine
old marine
