Hi, I am having problems with my ASK C5 compact projector, after it has run through its auto input search and has found the pc, it will only project a scrambled frozen vesion of the screen, all the menus are still accessable but I cant seem to change what is on screen, any suggestion?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 35 Answers
Try changing the resolution of the pc, sometime the projectors can not lock on to all resolution rates of the pc's, 1024 X 768 is a common resolutions that should be ok. If that doesn't work try another; 800 x 600. Also make sure if you are using a 15 pin HD VGA connection cable that the projector input is in the Analog mode.
Posted on Jun 19, 2010
Projector is not projecting
Hi Tama,
It sounds like you may be having an issue with the video inputs. This is something that needs the attention of a trained technician, feel free to send us a message if your problem persists: Projector Repair Bulb Replacement
Jan 17, 2014 | Optoma EP747 Multimedia Projector
Remote control code
the price for the remote control is USD30
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 18, 2013 | ASK Proxima C5 compact Lamp
Hi there, I'm trying to play a VSH/DVD through my
This happens when the computer signal is being used as the input, and the signal disappears or is the wrong type.
It may have tried switching inputs if you were using the video input rather than the pc input.
Press the auto image button to get it to select the correct input.
If you are using the PC as the dvd player, then change the display settings ie computer screen refresh rate, and resolution to suit the projector
Apr 06, 2011 | InFocus IN26 Multimedia Projector
Whe the projector is switched on and power light goes to solid green only a blank screen appears (basically only th lamp light) nothing else.
Be sure your input from the source is good. If a PC you may have to toggle the F8 or F5 to change the dispay to the projector. You can set the projector for AUTO Search to check all inputs at start up. If your doing WiFi or DVD/VHS player, be sure your using the outputs from those devices and that they match the projector input.
Feb 09, 2011 | Epson EMP S1 Multimedia Projector
Projector has image on screen but cannot get connectrion to laptop to project pwerpoint
Be sure you have the right input selected. You might try Auto Search. Then toggle the laptop using the F8 or proper function key to display the output to the projector or in both places. Sometimes the laptop must be hooked up to the projector before the laptop is turned on. Hope one of these works.
Feb 09, 2011 | InFocus Office Equipment & Supplies
SHARP NOTEVISION XG-C50X LCD PROJECTOR: Does this work for laptop presentations as well as DVD projections
Hi there, Sharp makes light and compact projectors with low fan noise. Set the projector up in areas subject to minimal humidity and dust to avoid having to clean the lens too often. Remember that colors will get washed out if the screen is in direct sunlight. Learn a few troubleshooting techniques to get the most out of this work horse projector.
No Pictures, Sound or the Projector Fails to Start
  • If you have no pictures, sound or the projector fails to start, check that the power cord is plugged into the wall and that all the cables are connected to the rear panel. Make sure the remote control batteries are fresh. If you are using a notebook computer, make sure the screen output is correct. Check the Input Mode on the projector. Check the projector physically--is the lamp and cover in place? Check the key lock.
  • Jul 31, 2010 | Sharp Notevision XG-C50X Multimedia...
    Cannot get LP340 to work on Vista pc
    Try Lowering your screen resolution slightly and/or booting up the pc after the projector is plugged in and running.
    Also if the 340 has multiple inputs check you are on the correct RGB or VGA input.
    Good Luck!
    Dec 17, 2009 | InFocus Projector Lamp for LP340, LP340B,...
    I have connected laptop to infocus projector and both are powered on. I have pressed Fn/F4 to toggle the laptop to project. However, Nothing will project!!! What can I do. I have checked the connections...
    make sure you have the settings correct on the projector. select computer on the top panel. if still nothing, reset the settings to factory default (in the menu). also make sure you have matched resolution.
    Nov 21, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Epson LCD Projector Model: EMP-S1H
    Hi there. What windows are you using? There are a few different ways of chaning it but usually diferent depending on what make computer and what windows you are running, but normally on xp you can go into display and go to the advanced settings, then click on graphics setting and it gives you the option to change everything including temp, saturation etc.
    Feb 01, 2008 | Office Equipment & Supplies
    USB Driver for PLC SU70 Sanyo Multimedia Projector
    Ok kumar i did some research on your problem.
    Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
    Now i want you to goto this website:
    http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
    This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
    -robert
    Jan 17, 2008 | Sanyo PLC-XU73 Multimedia Projector
    Televison & Video Logo
    42 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
