Question about Intermec 6820 Matrix Label Printer
Here when we giving print from HHC ,the paper coming out continuously without printing...we have switch off the printer for stopping this...we have changed its motherboard ,,after that the problem occured
    Problem Solver:
  • 4 Answers
Hi, check the sensors, if still the same, the paper feed motor, if still the same i need to program the control board! but i am working here in dubai here is my email address e.satorre@mirnah.com
Posted on Dec 08, 2010
When I put the paper in the feed, it just feeds without printing anything. I am unable to stop the printer, what can I do?
I have had part of this problem in the past. My printer kept printing and would not stop. In the end, I pulled the plug. Once up and running again, it was fine.
I expect you've checked ink levels. If they are ok, try taking out the ink cartridge and putting it back in, the start up again. The printer should then print a test page, and stop afterwards.
This is very basic, I'm not techie. If it continues to continually send out paper without printing, you probably need an expert. Good luck, hope it sorts itself out.
Aug 22, 2015 | Office Equipment & Supplies
Paper jams after printing 1/3 page. continue s to print on on wrinkled paper until file is totally printed
The rollers need cleaning. Office supply stores carry cleaning paper. It's sticky on both sides. Run it thru without printing on it. That should fix it.
Jan 24, 2014 | Epson Stylus Office Equipment & Supplies
HP 4100dtn Tray 2 picks the paper NON-STOP?
Step 1:Check with another cartridge
Step 2:Switch off the printer take out tray 2 casette, swich on the machine check while intializing the printer tray 2 pick up roller rotating?.. If its rotating check solnoid which is located right side under the main moto assembly, clean the solnoid as shown in the anap shot..fix it back.
Step 3:Open right ,left & top covers.., close cartridge access door check is it driving the laser scanner shutter?, if not check the sccess door knotch broken/bend.
Nov 20, 2011 | HP LaserJet 4100dtn Printer
Started out with paper, would start to load paper them as soon as paper stared in would stop. After several tries it would work. Then it stoped taking paper at all. Each time you try to print it stops and...
First I would remove the paper tray and check the rollers and print path for any scraps of paper that may be tripping up a sensor. If all seems well, ...
Try this next: It will reset the printer's configuration info.
To factory reset your Dell 1700 series printer follow these steps.
  1. Turn off your printer
  2. Open the front cover (push the button on the left side)
  3. Hold down the "Continue" and "Cancel" buttons and turn the power back on.
  4. When the "Error LED" light on the control panel is solid, close the cover and release the "Continue" and "Cancel" buttons.
Tip: To print a configuration sheet push the "Continue" button twice. This will give your printers IP Address.
Dec 31, 2010 | Dell 1700n Laser Printer
Power went off when I tried to print
Would be helpful to know which operating system you are using and whether there where any warning light flashing. For starters review the following solutions.
Printer Does Not Start or Stops During Print Jobs
Inner Cover was open when you started printing.
Close the Inner Cover and press the RESUME/CANCEL button on the printer. The printer resumes printing.
Inner Cover was opened while printing is in progress.
A page of print data being sent at the time of the error will be erased, so print that page again.
The printer has been printing continuously over a long period.
If the printer has been printing continuously for a long time, the Print Head may overheat. To protect the Print Head, the printer may stop printing at a line break for a period of time and then resume printing.
In this case, interrupt your print session at a convenient time and turn the printer off for at least 15 minutes.
Additionally, if the printer has been printing graphics or photos with intense colors continuously over a period of time, the printer may stop printing to protect the Print Head. In this case, printing will not resume automatically. Turn the printer off for at least 15 minutes.
i_expl.gif Caution
The Print Head and the surrounding area can become extremely hot inside the printer. Never touch the Print Head or nearby components.
Out of paper.
Make sure that paper is loaded in the selected paper source.
Reload paper if no paper is found in the selected paper source (Auto Sheet Feeder or the Cassette).
If the same paper is loaded in the other paper source, you can switch the paper source with the Paper Feed Switch or the printer driver to continue printing.
If both paper sources have run out of paper, confirm the selected paper source and load paper there.
Printing documents with plenty of photographs or illustrations.
When the POWER lamp is flashing green, the printer or the computer is processing data. Printing large data such as photos or graphics takes time for the printer and the computer to process, during which the printer may appear to have stopped operating.
In addition, when printing data that uses a large amount of ink continuously on plain paper, the printer may pause temporarily. In either case, wait until the process is complete.
i_note.gif Note
If you are printing a document with a large printing area or printing multiple copies of a document, printing may pause to allow the ink to dry.
Dec 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I am having HP 2300 LaserJet printer. From Yesterday it started printing continuously. When you give one test page from XP It will print that Test continuously without stopping. I need to cancel the Job...
Hello .
First select the configure device menu by up & down arrow keys in display select them by pressing green button find no of copies in sub menu change this value to 1 & set them by pressing the green button.Your value set to no of copies to 1 & your problem will be 100% resolved.
Sep 19, 2010 | HP LaserJet 2300d Printer
There is problem when giving print..thats the
check the sensors that makes the paper printer stops... 6820 and 6822 printers are one of a expensive printer in the market today and i been working of it for 3 years now as well as its handheld 700C and CN3... just email me in case it didn't give you a good solution coz theres a lot of approach to fix it. i do chip leveling....
Jun 04, 2010 | Intermec 6820 Matrix Label Printer
Epson cx7800 paper continually comes out - not printing
you need to download the scc to reset your printer if you can not find the software let me no and will give it to you
Oct 21, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Epson Lx300+ printing problem
hi
pls check printer test print
  1. switch off the printer .
  2. insert paper in printer
  3. hold the button ll/ff pressing .
  4. switch on the printer
if you get test print OK then. you need to be Reinstall Printer Drivers on your Pc
May 22, 2008 | Epson LX-300 Matrix Printer
Intermec 6820 Matrix Label Printer Logo
73 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
