Question about Krups Small Appliances Espresso Machine
THE XS6000 MILK FROTHER DOES NOT WORK? - Krups Small Appliances Espresso Machine
SOURCE: milk not frothing
called customer service. issue was, if you look at the hook where milk container connects,  you should see two rings, green  and black, if you don't this is what causing the issue.  they send me new once w/o questions asked...
Posted on Jul 19, 2008
SOURCE: THE NESPRESSO MILK FROTHER HAS STOPPED FROTHING
I contacted Nespresso who may well replace the item
Posted on Nov 27, 2009
  • 39 Answers
SOURCE: frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Posted on Dec 31, 2009
  • 21 Answers
SOURCE: My Nespresso milk frother did not come with
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
Posted on May 08, 2010
SOURCE: Lost my Nespresso Aeroccino Milk Frother Hot Milk Whisk
Call Nespresso customer service at 800-562-1465. Replacement set of 2 wisks were $2.95 + shipping
Posted on Jul 01, 2010
Hi, We have a Saeco Royal coffee machine and the milk frother doesn't seem to be working. Need some advice as to what could be the problem?
1- Royal Coffee is not an accurate model. I have to assume that you are having problem with the auto frother that is on the left side of the machine. The auto frother draws milk from the bottle and steams it into the cup.
2- The connection of the frother & the adapter is not right/air tight. The two O-rings on the frother must be pushed in all the way so the O-ring will not be visible.
3- The frother circular chamber for steaming is not clean. There should be no milk deposits visible at all.
4- The silicone tube puling milk from the bottle is connected to the body of the frother with an L-shaped connector. Make sure this connector is air tight fit.
Dec 20, 2016 | Saeco Coffee Makers & Espresso Machines
My breville milk frother was submerged in water and won;t work, how can I fix it?
If it does not work after _thoroughly_ drying it out, then the circuit board went bad from turning it on while it was still wet.
Feb 26, 2015 | Breville Milk Cafe Automatic Milk Frother,...
My nespresso milk frother red light doesn't come on, it is staying blue
I found that when I switched milks from whole to two percent organic it stopped frothing. When I tried a friend's creamer it worked again.
Oct 12, 2013 | Nespresso Aeroccino Automatic Milk Frother
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
The milk in the frother won't foam. I tried different kinds of milk but still doesn't work
the frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
Sep 14, 2010 | Nespresso Citizmilk C120
Wisk popping off
I have this same problem!
frother works fab, black whisk pops off every time i try to steam milk
Mar 31, 2010 | Nespresso Aeroccino Automatic Milk Frother
Frother not working
The frother does not have a vacuum, it uses venturi pressure to draw up milk through a venturi at the top of the steam feed. The milk side is clogged from not cleaning enough. soak in boiling water for a few minutes and try to run it in steam mode for a while... if that doesnt work, a light lye solution will dissolve the milk residue clogging it. neutralize the lye with vinegar drawn through after the clog is gone.
(lye will dissolve you as well as milk... use gloves and don't put your face near it while it's working.)
Apr 19, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Krups Small Appliances Espresso Machine Logo
242 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
