Question about Linksys Wireless-G WRT54G Router
Linksys Wirelss Router-G problem
The above router is connected to my internet router through CROSS cable for sharing internet but it goes OFF and ON at intervals.
Pls help
    Novelist:
  • 162 Answers
Hi. I would suggest that you chane the cross cable into a straight cable configuration, so that both router can transmit signal at the same time and might solve the issue of intermitent connection failure. Hope this Helps
Posted on Jun 04, 2010
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
I have changed my wirelss router toa Linksys and now need to set up wirelss printing from my HP6110. how do I do this? The new wireless router is a WRT310N.
You will need to check the wireless settings of the
router
is there any computer connected to the router ?
If yes then you can open the router set up page on
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
IS your printer wireless or it is connected to the computer.
If printer is wireless then you will need to connect to the wireless network.
If it is connected to the computer and you want to share the printer then you will need to enable the file and printer sharing on all the computers.
Click here for step by step instructions
Jan 23, 2010 | HP Computers & Internet
My xbox 360 disconnects my Linksys wireless router - i.e. - i have no wireless. Router still shows that I'm connected to the internet, but my wireless goes down whenever I try to automatically find the...
Its the issue with NAT settings,,,you need to login into the setup page of the linksys default address is 192.168.1.1,,,,change the mtu to 1365 ,,,,,disable the firewall and uncheck the block anonymous internet request under the security ,,,,,upgrade firmware under administration tab,,,,trigger the ports under application and gaming,,,,,port 80,88,3074,53...do these four things ,your problem will resolve
Dec 30, 2009 | Linksys 4-port Wirelss Router W/srx200...
My Linksys Wireless A P only allows one computer to connect
You need to get a router in order to share the Internet connection. The existing Internet connection (from the DSL/cable modem for instance) goes into the WAN port of the router/firewall, then you connect the AP to one of the LAN ports.
Today it is often a better idea to buy a wireless router instead, i.e a router with built-in wireless AP. They are very inexpensive.
May 28, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
I have switched internet to at&t dsl and now when i hook up wireless router i cannot connect to the internet can connect with only modem connected but not with both wirelss router and modem connected
hi there,
when you go through a router with dsl, your router stores your sign on and password. since you have a new providor, you need to get on your router's settings page through your browser, and change your settings to what at&t gave you. what did you have before-- cable internet? dial up? cable does not require an ID + password at all, your router will just pick it up. DSL requires that you tell the router what your sign on is... to get to your linksys login page, open your browswer and go to
http://192.168.1.1/
you have to 1st sign on to control your router-- usually it's username "admin" and no passwork... I hope you remember it!
second, the main screen, you need to punch in your AT&T info-- username and password. I assume it's PPPOE (PPP over ethernet)
hit save, and after it confirms, reboot your router (unplug for a minute) and your computer.
Jan 30, 2009 | Linksys Wireless-G WRT54G Router
With a Linksys Router is a 2wire modem needed?
Do you have internet service (Cable, DSL, etc.)? If so, a router is a great tool for keeping the bad guys out of your home network. If you don't have an internet connection, a router is very useful for connecting multiple computers together. In some cases, you may want to share resources with a neighbor (unlikely, but possible). A wireless router would be extremely useful in this scenario.
So in answer to your question, a router doesn't need a modem to operate but it does need an internet connection to get you on the internet. A router by itself does not provide internet connectivity.
Dave Grannas
Jan 26, 2009 | Linksys Wireless-G Broadband Router
Sharing internet with bt voyager 210 adsl router and linksys broad band router
hook you linksys uplink you cabel out from adsl router uplink other end goes to links wan
Aug 14, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
