Question about General Electrical Supplies
I have just got a second hand Quadpower Gen 2600 generator no manual, what oil does it take and where can I get a manual!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Go on line and type in the generators name and the manufacturers site will be there. they should be able to give you the specs and mail or email you a manual. usually there is oil designed for generators since they run at such high rpms for so long and it is found at parts stores and anywhere they sell generators but check with your manufacurer first in case they use something different in your unit.
Posted on Jun 04, 2010
What's the best oil for Honda em 400 power generator?
S.A.E grade 10w-30 multi grade oil its recommended from 60F and up.
For temp lower than 60F use the 20W oil
if its a new Gen(first operation). replace oil after 20Hr.
Other than that in normal working environment replace oil evry after 100Hr.
Dusty area shorten the time of replacing oil and cleaning air filter.
remember not replace hot oil or if the Gen runing !!
Mar 18, 2016 | Honda Electrical Supplies
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Propane gen starts runs for 10 seconds then shuts down. does this 3 times
Sounds like the oil pressure sensor is not detecting proper pressure. Be sure you have adequate oil and that the sensor line is connected.
Jan 05, 2015 | Briggs & Stratton Electrical Supplies
Briggs/Stratton 7K propane gen starts runs 10 seconds shuts down
Sounds like an oil pressure sensor issue. Be sure you have adequate oil volume and that the sensor line is connected.
I've noticed oil leaking from the unit but don't know where its coming from.
check at joint between engine and gen, its usually the engine oil seal need replacing u will need to split engine from gen, and replace the oil seal
Oct 11, 2013 | Groove Tubes Power Back 5,250-Watt...
Eb7000 won't stay running after 12 seconds disconnected the oil sensor wire but no change
Check rotor slip rings for tarnish, gen control needs to sense stator voltage is produced
Jul 28, 2013 | Honda Electrical Supplies
I have a 12kw lp gas genwrator that starts and runs for about ten seconds and then shuts down.after maybe 25 tries doing this the generator will stay running and then i try and start it again and it will...
These type of gens have a low oil shutoff. Check the oil. Always have spare spark plugs, a cheap fix. My gen always wanted a new plug every year. Look to see if it has a fuel filter.
Sep 24, 2011 | Generac 13,000 Watt / 13,000 Watt Home...
Can you help me? I have generator yamaha ef 2600. Generator normally running about 3 minutes then rpm comes unsteady and gen stops. Moreover at load 2kW gen immediatly works unsteady and stops. Without...
As you describe the problem, the reason is unstable load handling.
This means that the fuel or air is not enough.
When begin to be unsteady:
  1. If smoke comes out of muffler - the input air is not sufficient. Try to clean or change air filter (cleaner).
  2. If no smoke, the fuel is not enough. The reason may be the mechanical governor, or the fuel supply to it, fuel filter/strainer etc.
Aug 05, 2010 | Yamaha 2300 Watt Generator - EF2600
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Electrical Supplies Logo
316 people viewed this question
Top General Electrical Supplies Experts
nirodacyar
rhodesworks
JonSnell Electronic
JonSnell Electronic
Are you a General Electrical Supply Expert? Answer questions, earn points and help others
