Question about Belling BIM60 Microwave Oven
Belling microwave 700w has stopped working
I,ve had this microwave for 35 years and only changed a bulb once. it,s always given good service, so if i have to by another micro what would i be looking for ,the size of turntable plate is 55cm across. can you suggest a similar sort , just a basic one that has high and defrost on.
the list number is MW1.
the serial number is 43402.
many thanks,
3 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: Belling Microwave Problem
Apparently this one has a mechanical timer. That lack of electronic controls does lessen the complexity. I don't know about the specific regulations concerning British / EU microwaves, but I'm sure there's a fuse inside. In most cases, just replacing a blown fuse will not be the cure, unless one finds the reason it blew. What made it fail (if it did) is the real question. Loose fuse holder allowed excess heat? Shorted component or wiring? Or, is there a failure in the mechanical timer that's causing an open circuit connection? That can certainly happen. Also, a door switch may have failed. This is most commonly caused by opening the door while it's cooking, instead of turning the oven off first. I would suggest you contact Belling service: http://www.belling.co.uk//CMPage.aspx?pageid=130&subsectionid=85§ion=ContactBelling Good luck.
Posted on Oct 11, 2006
grandadfixer
  • 99 Answers
SOURCE: Belling microwave
Turn table motor open circuit/drive shaft damaged
Posted on Oct 18, 2008
My light bulb has stopped working and will not work after I have replaced it with a new one
It could be either a separate door switch for the light that's gotten crufty (sometimes just cleaning them makes them serviceable) of the microwave that needs to be reset. Just check for tripped circuit breakers, since you've already unplugged the thing to swap the bulb (I expect.) Then check your bulb's continuity, then check the socket and switch functions if things aren't sorted.
Sep 10, 2011 | Whirlpool MH1141XM Microwave Oven
Changing the interior lightbulb of Maytag #MMV5207BCW over the range microwave? How the #$!% do you get the cover off to change the bulb?
I have a belling combi microwave, the covection oven works well but the microwave oven has stopped heating the food up and also the defrost isn't working ? Any tips or does it need repairing and wat are the costs?
Nov 24, 2009 | Maytag Appliances Over-the-Range Microwave...
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
Light has stopped working in microwave
Do you have an owners manual, if not go to the manufacturers website and download one, or call and get one, it should have instructions on changing the bulb, I have changed bulbs in a variety of microwave type ovens, and not one was the same access, some you have to remove the side control panel face, others a top plastic case part, too many to list, you need to find out the manufacturer's directions and or study the unit, with enough looking you will find an access point, generally this is somewhat complex, a few screws minimum, next is to be careful in the disassembling of a microwave, if you are not sure where or what you are taking off, you can take off, parts that allow the microwave to leak, or become dangerous to be around, find the specific instructions, it will make life much easier for you.
Will
Nov 30, 2008 | Belling Microwave Ovens
Change the bulb
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Nov 22, 2008 | Belling BIM60 Microwave Oven
How to change the bulb in the micro oven (Stainless steel 700w, 17L) I guess the model no is BMO700S
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Aug 10, 2008 | Microwave Ovens
GE Profile XL 1800
It's a little more complicated than Leo2 suggested but the general concept is correct. *NOTE: Turn off power to the microwave first before servicing it!
At the top of the microwave there are three screws.
Remove the three screws and slowly pull down from the top to get the plastic airvent out of your way.
You will notice a plastic vent with two screws. Remove the forward screw and then pull from the top of the vent to access the rear screw. Now you have access to a metal plate above the fan assembly. Remove the screws at the leading edge to lift up the plate. You don't need to remove it, just lift it up!
Now you have access to the metal box over the lightbulb. Squeeze the box and the box with the light bulb inside come out as one unit. You'll know you have the correct bulb as it is attached to two white wires. Remove the bulb. Should be a halogen 120-130 volt with 35 watt brightness. Remember, halogen bulbs should never be handled with your bare hands. The grease from your fingertips heats up and the bulb burns out prematurely. Always handle these bulbs with rubber or cloth gloves. They are expensive little sucks ($7.79 at Home Depot) so handle them with care!
Good Luck ...
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Oct 11, 2006 | Belling BIM60 Microwave Oven
Belling BIM60 Microwave Oven Logo
73 people viewed this question
Top Belling Microwave Ovens Experts
William Miller
William Miller
ray gallant
Tim Rickards
Tim Rickards
Are you a Belling Microwave Oven Expert? Answer questions, earn points and help others
