Question about Canon FAXPHONE L170 Plain Paper Laser
L170 Canon Fax Sound and volume control issues
Model: Canon Fax L170. I have turned off all sound and lowered the volume. The unit continues to beep loudly (very loudly) when an incoming fax occurs.
It would be very much appreciated if someone could  help. I have used the menu button and used setup to turn off all warnings and turned down volume. I'm ready to have a heart attack each time an incoming fax occurs.
  • 22 Answers
Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
Posted on Apr 22, 2008
HOW CAN SOLVE ERROR E225-0001
E225-0001
Detection
Insufficient lamp light intensity (The light intensity is at the reference description level or below.)
Remedy
When the same error repeatedly occurs although the power is turned OFF and then ON for several times, execute the following remedies:
(1) Check the connection between the Main Controller PCB and the CIS Unit. (J2)
(2) Replace CIS Unit.
(3) Replace the Main Controller PCB
Canon L100 Service Manual Page 161
May 18, 2015 | Canon FAXPHONE L170 Plain Paper Laser
Canon FAX-L170 error E000-0000
canon fax-L170 trun the main power on.
E000-0000
Oct 24, 2013 | Canon L170 All-In-One Laser Printer
Volume on Canon Faxphone L170
By pressing the menu button left of the LCD display,scroll to usersettings press ok.Scroll to volume settings press ok and change volume levels there.
Dec 11, 2009 | Canon FAXPHONE L170 Plain Paper Laser
We have a Canon Faxphone L170. Someone sent a fax
On the controll panel there is a diamond shape picture with a eye in it.press that bottom and clear the fax that you received.There is no other way.You will have to phone the sender and ask them to change the papersize settings on the fax machine.
Dec 08, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Would like to receive legal faxes through mpf on my canon l170
Starting on page 4-8 and continuing thru step 3 on page 4-9 will allow you to setup the mp feeder for legal size paper on your Faxphone L170.
http://gdlp01.c-wss.com/gds/0900006140/FAXPHONE_L170_Basic_Guide_EN.pdf
Oct 26, 2009 | Canon FAXPHONE L170 Plain Paper Laser
The Canon L170 will not grab the paper.
Yes,remove the 2 screws at the bottom of the docfeeder,then the lower side of the dockfeeder will come apart.Remove the tention spring of the separation and lift the separation upwarts,then you can install the new separation.
Jul 13, 2009 | Canon FAXPHONE L170 Plain Paper Laser
The ring is very loud when a fax comes in, volume control where?
This needs clarification. Is it the Handset on the machine that is ringing? If so there is a small slider control on the handset that can be adjusted down with a paper clip.But if the fax itself is to loud you'llneed to go inot programming and selct the Monitor Volume and set it lower or off.
Jul 09, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Volume
Press(menu),press arrow left untill (common Settings),Press (ok)Press left untill(volume Control) is shown.Press (ok).Choose the different volume control for the machine here.You can also choose to switch the volume completely off.
Dec 08, 2008 | Canon FAXPHONE L170 Plain Paper Laser
LOUD SOUND WHEN SENDING FAX
There are 4 volume controls to access them press MENU.
You should see “MACHINE SETTING?” if not use the SET arrows to scroll through the different menus, stop when you see “MACHINE SETTING?” Now press the SET button.
Now use the up & down arrows to get to
Buzzer Volume = that the machine beeps
SET
Key volume = the tone that sounds when you press keys on the control pad
SET
Alarm volume = the alarm if something happens.
SET
Line volume = sets the level you hear at the fax is actively transferring a fax.
If you want to change any of the settings, press the up or down arrows to the level you like best and press SET if you don’t what to change that item just press SET. When you have adjusted all levels the way you want them press STOP and the levels will be remembered.
The most annoying sound to most people in the Line Volume. I have known people that like it as quiet as posable in thier work, but the problem is if you turn down the ALARM you won’t know when there is a problem. Many people like a little line volume so that they hear when they dial into a busy phone line, or if someone picks up the shared voice line.
Feb 12, 2008 | Canon L120 Fax Laser Printer
No dial tone, clicking sound
It most likely is the LIU (Line Interface Unit). or you might have it plugged in the wrong port on the fax itself. Make sure it's plugged into the LINE plug. If it's the LIU it would be cheaper to replace then calling for service. Unless it's under warranty still (usually 90 days)
Jan 29, 2008 | Canon FAXPHONE L170 Plain Paper Laser
Canon FAXPHONE L170 Plain Paper Laser Logo
1,055 people viewed this question
old marine
old marine
