Question about Kohler Plumbing
IM ROUGHING IN PLUMBING FOR A SHOWER TOILET AND SINK. 8 BY6 BATHROOM FROM SCRATCH CAST IRON STACK ALREADY CUT AROUND REMOVE CEMENT SHOULD THE WHOLE INCLUDING CLEAN OUT , REPLACE IT WITH PVC OR JUST CUT IN INSTALL BOOT AND MY Y IN THE CAST PIPE WEVE DUG AROUND , ITS HAD IT BETTER DAY ,WONDERING IF THE BEST WAY , REPLACE THE BOTTOM OF THE STACK FROM JUST ABOVE CLEAN-OUT DOWN TO COUPLE FEET UNDER THE CEMENT WHERE CAST IS IN ROUGH SHAPE . ATTACHING CAST TO PVC IS THERE A PROBLEM , JUST THE RIGHT BONDIND PRODUCT AND FITTINGS. SORRY IF YOU UNDERSTAND WHAT IM TRYING TO EXPLAIN .THANKS
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Always replace cast iron if its not a problem to do so, especially if it looks rough or is leaking or rusting. there are simple special black neoprene boots used to connect cast iron to pvc and do not require anything but a screwdriver, no slovents or sealers are required. always check for leaks if you make an underground connection before you cement the spot back up. its better to use gravel to fill this area in if your particular situation will allow.
Posted on Jun 04, 2010
What is a galley holding tank?
The galley holding tank holds the grey water from the galley.
May 24, 2017 | RVs
How to install toilet plumbing
This is not possible. The drain is much smaller from a shower . The feaces would get stuck
Jan 10, 2014 | Home
Can you tie into a common dscharge pipe when plumbing a sanivite and saniplus?
I think it can be done , but it may be against the local code for your area. The obvious concern is back up of sewage in the sink, and washing machine.
Feb 01, 2013 | Home
Bathroom sink smells strongly like sewer when water runs fast.
Suppose you plugged the drain of the sink and filled the basin with water, then removed the plug. I must think that only after the basin empties you would get the sewer smell, and the smell would persist until you slowly ran some more water. If you try this, and this is the result, then the problem is that the sewer vent (that is supposed to prevent the water in the trap under the sink from being sucked down the drain) is not working right. If this is a new problem then you may be able to clear what is probably a blocked vent pipe. If this bathroom has always had this problem, then you have a poorly designed or executed vent pipe setup that you can only fix it with some surgery to your plumbing. However, to clean the vent you can try pouring a good bit of drain cleaner down the vent pipe on the roof, followed by water. But because there may be several vent pipes sharing the same vent stack out the roof, the drain cleaner may not get to your blockage and may simply go down a different path. Good luck.
Oct 15, 2012 | Plumbing
Sewage backs into the shower when the toilet is flushed
Obviously the drain line from your toilet to main drain out of the house ( used by upstairs ) has a blockage from your toilet line to "Y" in to main drain line. Depending on how it has been plumbed, there may be a clean-out between the 2 that can be used to remove the blockage. Your drain for shower is piped in to same line as toilet, thus when blocked at other end, overflows to shower. You can try some drain cleaner down shower drain if it will go. You might get lucky and release the blockage before plumber shows up .
Sep 16, 2012 | Home
I am about to install a bathroom with shower bath sink and toilet , each will run seperatly to the outside soil stack. Do i need air vents on each run
Every drain needs to be vented to work properly. Usually, you can run the vents collectively to the stack ... Please check your local building code for important particulars that will affect how you do this work.
Thanks for your interest in FixYa.com
Feb 07, 2011 | Home
Water Leaking around Ceiling Vent in Kitchen
it is likely a small leak i'd get a plumber money well spent you don't need the expense of a flood or search with a very brite flash light.Tom
Jun 18, 2009 | Heating & Cooling
How to remove a cast iron kitchen sink installed
Turn the water supplies off unscrew the hoses,get a flashlight and look under the sink you should see clamps around the top holding it in, unscrew these and pull the sink out.
Len
Feb 22, 2009 | Eljer 212-1088-00 White Dumount Double...
Plumbing Logo
135 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
