Question about IBM Computers & Internet
How to intall windows 2003 oparating system to scsi drive...
How to intall oparating system to scsi drive...
    Scholar:
  • 103 Answers
When you install Windows you set first CD/DVD drive as the first to boot then the installation begins, as you get to a point where installation is loading (you will see a blue screen), in the bottom part you will see instructions...to be exact;
--- Press F6 to install scsi drive (something like that)
-----just follow the instructions
Posted on Jun 04, 2010
I cant intall window 2003 in IBM server x3400 , wher to find the SCSI driver < took me 24 hours and i didnt find it yet anyhelp thx.....
You can install Windows 2003 using IBM Service Guide CD. Its an image file (.iso) . Burn it after download . Then boot from cd and follow the simple wizard . Find the link below
http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-5088993
Thanks
Nov 15, 2011 | IBM x3400 Server
Trouble installing Windows Server 2003 on Netfinity 5500
Disabling Application Error Reporting on Windows Server 2003 (and XP, also)
Preface:
There is absolutely no good reason to disable this service in pre-release, or released software. If a program or computer crashes, then once the computer recovers it makes a detailed report (with no personally identifiable information it) about how the crash happened and sends it off to Microsoft. They then look over it, and try to fix it, which makes a better OS for everyone. This is not a recommended procedure.
Method:
Click the Start button, and right-click My Computer and click Properties from the pop-up menu
my-comp-properties.png In the System Properties dialog that has come up, click the Advanced tab, and then the Error Reporting button
system-properties-advanced.png In the next dialog click the Disable radio button, and optionally, so you don't get any notices of system failures at all, uncheck But notify me...
error-reporting.png Now press OK, Apply, and OK, and Error Reporting has now been disabled.
Jun 24, 2008 | HP Compaq ProLiant DL380 G4 Server
Can not intal canon pixma mp 140 on windows 7 32 bits
it is problem your printer driver or oparating system is corupt by virus please install again or
setup add printer then if you are saw a new hardware detect then select devise driver
Sep 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hello, I installed Windows 2003 server on SCSI
what is the error message u r getting..
check for the jumper settings might be there is some problem with the jumper behind ide
need more clarifications from u
Sep 27, 2009 | Computers & Internet
New install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
May 26, 2009 | IBM x3400 Server
I can`t install window xp before have intall window vista for demo.when installation begin,before the loadind a files,my computer standby.
hi dear you need SCSI drivers if you using SATA hard drive you cant install
you have find scsi driver for your hard drive 1st after onlyyou can install
windows xp
Thank you
Imrna
Pls rank me as possible have nice day
Apr 21, 2009 | Microsoft Windows XP Professional With...
Can not install windows server 2003 on Acer Altos G710
Hi! Turn off computer check cable & power cable connection. Windows 2003 Operating System will not support SCSI Drives.
Apr 08, 2009 | Acer Altos G710 Server
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
Windows 2008 on IBM x346
I used this one with good result:
http://www.adaptec.com/en-US/speed/scsi/windows/a320raid_win2k8_x86_b212_exe.htm
Nov 11, 2008 | Microsoft Windows Server Standard 2003 for...
Toshiba DVD ROM SD M1302 driver
If you are using Windows 98, 98SE, ME, 2000, NT or XP, and have an ATAPI/IDE CD/DVD drive, there is no driver needed (see Toshiba statement I have posted below). Under no circumstances, if DVD is properly installed and functional, will you need ANY driver!
If your DVD drive is a SCSI drive, then it may need drivers specific to the SCSI card you have installed (see the specs/manual or website for your card). You may also need the Adaptec SCSI setup, available at this address:
http://www.adaptec.com/worldwide/support/suppbyproduct.jsp?sess=no&language=English+US&cat=%2FTechnology%2FSCSI+Software&fromPage=driverindex
or use this address if you have a LOGIC based SCSI card or device:
http://www.lsilogic.com/
Now, if you meet the criteria for the first paragraph I wrote, and your PC does not load the driver automatically (after a reboot or two) then you have a PHYSICAL or HARDWARE problem. Either the DVD drive is improperly cabled, improperly installed or defective.
Those are all your options. See below, from Toshiba website
good luck
http://sdd.toshiba.com/main.aspx?Path=ServicesSupport/DeviceDrivers
ATAPI CD-ROM and DVD Drivers
Toshiba's CD-ROM and DVD-ROM drives do not require any unique device drivers for Windows '95/'98/2000/XP/NT.
After installing your drive and re-booting, your system should recognize your CD-ROM or DVD-ROM. Win '95/'98/2000/XP/NT Operating Systems support all Toshiba ATAPI CD-ROM and DVD-ROM drives natively.
DOS/Windows 3.x Device Drivers
This device driver is to be used with DOS/Windows 3.x operating systems. Do not use this driver with Windows '95, Windows '98, XP or Windows 2000 unless you are going to use your system in the REAL or MS-DOS Modes. Device drivers for Windows '95, Windows '98, Windows 2000, XP, OS/2, and NT operating systems are provided with the installation or setup software of each operating system.
DOS ATAPI Interface Driver
If you prefer using DOS click the link below to download a MS-DOS ATAPI interface driver.
atapi.exe
SCSI CD-ROM and DVD Drivers
SCSI interface drivers are written for the SCSI card you are using in your system, by the SCSI card manufacturer. They are not specific to your Toshiba drive and are not provided by Toshiba. If during installation Windows can not find the correct SCSI software driver for your SCSI card and you do not have the software driver that came with your SCSI card, contact your SCSI host adapter manufacturer.
Adaptec SCSI Drivers
LSI Logic (Symbios) SCSI Drivers
DVD Viewing Software
Toshibas DVD drives require a third party software to be installed in your system to enable you to view DVD movies. If you purchased your drive as part of a kit, the software may have been included. The links below will provide some possible solutions should you not have this type of software.
Nero6 (Toshiba recommends)
Toshiba does not recommend nor endorse any of the following manufacturers software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
DirectDVD
Cyberlink PowerDVD
WinDVD
Media Burning Software
Toshiba's recordable drives require third party software to be installed in your system to enable you to burn media. If you purchased your drive as part of a kit, the software may have been included. The link below will provide some possible solutions should you not have this type of software.
Toshiba does not recommend nor endorse any of the following manufactures software products. Software names are provided only as a courtesy to our customers. Please check with the software manufacturer to assure that their software supports your drive model.
NTI CD & DVD Maker
Gear DVD & CD-RW
Roxio Toast (Macintosh)
Easy CD Creator
Stomp Clinkn Burn Pro
Feb 24, 2008 | Computers & Internet
Computers & Internet Logo
418 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
