Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Hotpoint Aquarius not completing finally spin and pump out.
Fault ?
on/off flashing, Reduce Creases light on, Time Saver light on.
Please help
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The
filter is inside the machine. Turn off the power and pull out the machine to
get to the rear. Pull out the hose you
see going into the wall pipe, lay at floor level or plastic bag to drain out
remaining water in machine. Remove the panel at the bottom (2 screws) where the
discharge hose comes out. You should see a black concertina type tube coming
from below the drum attached by a jubilee clip. The filter is inside. Loosen
the clip and pull away the tube, take out the filter and clean it. When you
replace it don't forget to put the ball float back in (exactly as you found it)
and check it’s well fixed by running a spin cycle before sealing up. Caution, the exit drain hose shd be fitted at
the exact location where you found it, abt three feet up from ground level.
Pl
rate me nice for the free help, thnks.
Posted on Jun 04, 2010
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Feb 15, 2010 | Hotpoint Washing Machines
Dec 08, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Aug 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
May 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Dec 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Jun 11, 2008 | Hotpoint Aquarius WD640 Front Load...
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
773 people viewed this question
