Question about Samsung SF-335T Plain Paper Inkjet Fax
WHAT IS A PEN ON A SAMSUNG INKJET FAX SF-370,MY FAX DISPLAYS THIS MESSAGE USED CARTRIDGE IS INSTALLED & I WANNA REMOVE THIS MESSAGE
  • 4 Answers
Plug power while pressing the stop/clear button for 5sec
this will full initialize machine
Posted on Aug 06, 2010
Our fax machine displays jam 0 samsung sf 5100
Open the door take the cartridge out clean the roller at the back with dishwasing liquit and see if there is no paper stuck in unit. put ther cartridge back and take the power out and hold the red stop button in and put power back.
Aug 19, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
How do you change the ink cartridge on samsung sf31oo
Hi
It's very easy to remove the ink cartridges of Samsung printers. I have provided you the link to download and see the manual of the printer you are using, please go through the weblink and you can easily remove the ink cartridges.
Here is the weblink
http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=06011300&prd_mdl_cd=SF-371P%2fXIP&prd_mdl_name=SF-371P
Jan 28, 2010 | Office Equipment & Supplies
Everytime I send a fax from my samsung sf 370 i get
It can be the other person's fax or there is something wrong with your lines. Conect fax to another line then try again.
Oct 01, 2009 | Samsung SF-350 Plain Paper Inkjet Fax
Replaced Ink on Samsung SF-330 and still says install ink
There is something wrong with the cartrige head. First try to take out the cartrige and in the head there is contact points. You can try and clean it with a dry cloth.
Aug 18, 2009 | Samsung SF-330 Plain Paper Inkjet Fax
Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
Jun 02, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Samsung SF560 Message reads "toner empty". Replaced new toner cartidges and still get same message. have change toner in fax but getting message (jam 1) or toner empty it seems pretty common problem as...
Turn off the Machine for safety.
- Try to double check if the toner cartridge is properly installed
- Clean it also if dusty
- Make sure he sensor have no paper or dust.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF560.
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
Aug 31, 2007 | Samsung SF-560 Plain Paper Laser Fax
Samsung SF-335T Plain Paper Inkjet Fax Logo
574 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
