Question about C3 RS6652W (NEW with 1 LCD Transmitters) 2way 3Channel Vehic
All of the sudden my light quit flashing and horn stopped working on arming and disarming. how can i resolve this?
  • 171 Answers
The alarms is in valet mode. Find the toggle or push button switch. Put the ignition key to the on position and then move or keep pressed the toggle/push button switch until you hear a beep. turn the key to the off position and try it.
Posted on Jun 05, 2010
How do you stop the lights flashing when you change the battery?
DID YOU PRESS YOUR ALARM REMOTE TO DISARM THE SYSTEM OR DOES THE CAR START IF NOT DISCONNECT THE CABLES AGAIN AND THEN RECONNECT WHEN THE ALARM STARTS (YOU MAY NOT HAVE A HORN)FLASHING LIGHTS PRESS THE DISARM BUTTON ON THE REMOTE AFTER THAT SET YOUR CLOCK IF THIS DID NOT HELP BEING MORE SPECIFIC WILL I'M NOT THERE WITH YOU
Feb 19, 2015 | 1999 Mercury Grand Marquis
How do I disarm the alarm system in my 1999 Toyota Camry? My system has been dead for years but suddenly activated tonight. I tried all of the buttons on the remote, but the red light next to the steering...
Watch the video first, up to the bit they remove the steering wheel.
Take out the horn cable.
Reasemble the steering wheel.
This will stop the horn, but the lights will still come on.
Aug 23, 2013 | Toyota Vehicle Parts & Accessories
Replaced battery in my 1993 jeep grandcherokee limited now security system seems to cut fuel off seconds after engin fires
Here's some info as it sound like the theft deterrent is armed.
Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Feb 11, 2013 | Dodge Stratus Cars & Trucks
The alarm system has activated and we cannot disarm the system via the Remote Key Fob or by key at the doors or hatchback. Tried disconnecting battery same problem. When the doors open the system...
Hi Edward:
In dashboard, your THEFT warning light is blinking? If the answer is yes, your antotheft system is activated and will need restart and resynchonized. This occurs when battery is disconneting or other un-authorized key is used.
Vehicles equipped with Vehicle Theft Security System (VTSS) are protected from vehicle theft andunauthorized entry. VTSS system monitors vehicle doors, hood, liftgate and ignition. If an attempt is made toenter or operate vehicle without proper disarming of system, vehicle horn will sound, headlights, taillights andparking lights will flash, and engine will be prevented from running.
VTSS system arms when ignition is off, vehicle is exited, door is locked using power door locks and door isclosed. Alternatively a remote keyless entry transmitter can be used to arm system. A security light on panelwill flash for 15 seconds to indicate system is arming. At the end of 15 seconds, if no door, hood or tailgate isopened, system is armed.
If alarm is triggered, horn will sound for 3 minutes, and lights will flash for an additional 15 minutes. If hornsounds 3 times when either front door is unlocked, vehicle has been tampered with (tamper alert). If doors arelocked manually or with key, system will not arm (manual override). If an unauthorized entry does occur, VTSSsystem signals Powertrain Control Module (PCM) to prevent vehicle from being driven. PCM reduces injectorpulse width to zero, causing a start and stall condition.
System can be disarmed with the keyless entry transmitter, or by using key to enter vehicle. In both instances, if alarm was activated, vehicle alarm will be terminated. If battery is disconnected and reconnected, alarm will beactivated and it will be necessary to disarm system as indicated.
Please, send us some email account to send you this procedure in PDF format file.
Feb 08, 2012 | 1996 Jeep Grand Cherokee
How do i reset my alarm on a 97 jeep Grand
Here is excerpt from the 1998 Jeep Grand Cherokee Service Manual ... i know you posted under 1997 JGC but this information may be helpful ... by "reset alarm" i believe you meant disarming the alarm?
Arming
Passive arming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is exited with the key removed from the ignition switch, the headlamps are turned off, and the doors are locked using power lock switch. The power lock switch will not function if the key is in the ignition switch or the headlamps are on with the driver’s door open. The VTSS will not arm if either front door or the liftgate are locked using the key in the lock cylinder.
Active arming of the VTSS occurs when the Remote Keyless Entry (RKE) transmitter is used to lock the vehicle, even if the doors and/or the liftgate are open when the RKE transmitter Lock button is depressed. However, the VTSS arming will not be complete until all the doors and the liftgate are closed.
Following successful passive or active VTSS arming, the VTSS set lamp on the top of the instrument panel will flash rapidly for about 15 seconds after the illuminated entry system times out. This indicates that the VTSS arming is in progress. If the light stays on steadily during the arming, it indicates that the hood switch is closed (the hood is open). The VTSS will still arm if the hood is open, but the engine compartment will not be protected. Once the 15 second arming function is complete, the set lamp will flash at a slower rate to indicate that the VTSS is armed. Disarming Passive disarming of the Vehicle Theft Security Sytem (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter. Once the alarm has been activated (horn sounding, exterior lights flashing, and the the engine no-run feature), either disarming method will also deactivate the alarm. Depressing the Panic button on the RKE transmitter will also disarm the VTSS, but the horm will sound and teh exterior lamps will flash for about three minutes as a part of the Panic feature function. ..." And as an additional note, if you have the courtesy interior lights set at 30 seconds like i do, you have to wait until lights go out (with alarm still sounding) before you can disarm the alarm via passive disarm method... what a pain when you don't have the actual RKE handy... Good Luck!
Feb 14, 2010 | 1997 Jeep Grand Cherokee
I have a few lights flashing on dashboard after the battery was disconnected
is it the alarm going off ? , perhaps the horn siren was disconnected. Try arming and disarming a few times that might be the issue. Especially if the vehicle will not start.
Dec 05, 2009 | 2007 Subaru Legacy 2.5i SE Sedan
How do i enable factory alarm system without keychain remote?
The Simple Act of Locking the Driver side Door WITH KEY Arm the Factory Alarm. And UNLOCKING Same Door with KEY Disarms it The FOB < Rmote for Alarm Just Honks Horn and Flashes Lights, But it Does the SAME ARMIND & DISARMING. I Hope this Helps You out !!
Jun 15, 2009 | 2000 Pontiac Bonneville
How can I reset my Factory Alarm on my Jeep it wont run
Alarm Module Reset Procedure
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the lift gate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Jan 28, 2009 | 1999 Jeep Grand Cherokee
Alarm won't beep when doors are locked with key fob
hold both the lock and unlock buttons for three seconds the horn will honk and the lights will flash!
Nov 16, 2008 | 2002 Nissan Altima
C3 RS6652W (NEW with 1 LCD Transmitters) 2way 3Channel Vehic Logo
265 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
