Cannot send fax lid open cannon jx200
Cannot send fax when I try to send appears on display:'' lid open'' it is a machine cannon jx200 thanks a lot
  • Anonymous Mar 12, 2014
    How do I send a fax from my cannon mx452
    Guru:
  • 1,049 Answers
The lid sensor is damaged or out of alignment. You can sometimes wedge the push arm back into place or else permanently wedge the sensor into the on position.
Posted on Jun 04, 2010
Please send me fax manual for Canon-JX200. message
Please send me an email to LBrown18062@hotmail.com and I will send you the manual right away. Please put CANON FAX JX200 in the subject line and I will send you the manual right away. Lawrence Brown
Oct 24, 2011 | Canon FAX-JX200
NEED TO TURN ON AUTO PRINT ON CANON FAX -JX200
You can enable memory receiving feature temporarily.
1 Press [ON/OFF] to select .
􀁺 The fax starts receiving documents in memory.
􀁺 To cancel, press [ON/OFF] again.
If you would like for me to send you the user manual for the JX200, please send me an email to LBrown18062@hotmail.com Please put CANON JX200 MANUAL in the subject line and I will send you the manual right away. Lawrence Brown
Oct 11, 2011 | Canon FAX-JX200
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
Note
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
Is there a fax manual for this Canon Fax-jx200
http://www.usa.canon.com/cusa/support/consumer/copiers_fax/inkjet_fax/fax_jx200#BrochuresAndManuals
Dec 07, 2010 | Canon FAX-JX200
Salut....nu stii ai instructiuni in limba romana pt fax canaon fax-jx200??
I do not speak your language, but it appears you need instructions for the JX200. Go to canon.com, choose the correct country, go to Support, Downloads & Drivers, and then the manual should be listed. Thank you for using and rating FixYa - and if you need more help, please post back in English. Thank you!
Aug 21, 2008 | Canon FAX-JX200
Cannon Fax JX200
The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which appears to be your setting, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls based upon the times that are input in the settings of the machine. It would seem that the best thing to do would be to lengthen the times involved - particularly at step 7 below. I would imagine it is set at a low number - perhaps 10 seconds or less - and needs to be increased to give you sufficient time to answer the call.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically.
If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice.
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
It may take a few rounds of going through these steps to get the settings just right for your situation, but it should definitely solve your problem. If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution.Thank you for using and rating FixYa!
Jul 13, 2008 | Canon FAX-JX200
Getting the JX200 to receive and send faxes
Your response to my email is a bit late - we returned the machine to our supplier two weeks ago.
Jul 11, 2008 | Canon FAX-JX200
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
37 people viewed this question
k24674
