Question about Saws
How to tighten blade on super sawcat model 2154 , blade spins and I cant find any way to stop spindle from spinning when Im trying to tighten . Any help would be great as was my fathers saw and would still like to be able to use as he had many years of faultles use with this saw .
  • 59 Answers
Usually on portable saws there is a hole somewhere in the blade guard to put a screwdriver or something through and hold the blade still while you tighten the spindle nut etc.
Hope this helps. I only have experience of a very old B&D saw which worked in this way. I now use a more modern Bosch machine which also works the same.
Posted on Jun 05, 2010
I had the same problem with my 8 1/4 Super Sawcat. As tight as I could get the blade, it would spin on the arbor.
The problem is the washer with the 3 tabs that goes on before the bolt. From spinning, this washer has been worn down and is now thinner than it should be, which will not allow the bolt to tighten to put enough pressure on the blade to prevent spinning.
Also, when the saw was designed and put into production, the standard blades were thicker than most of the ones you buy today. So if you put a thin blade on, the bolt tightens against the arbor BEFORE the blade is actually tight, allowing it to spin.
The solution is to do one of two things.
1) Replace the factory 3 tabbed washer with a new one. May be hard to find - good luck. And will not address the thin blade syndrome.
2) (Best Solution) Find a thin flat round ordinary washer with an inner diameter that just fits over the arbor. Put this washer on before the factory 3 tab washer and tighten the bolt. Pull back the guard, stick the blade on a piece of wood, push down on the saw as you tighten the bolt and you are good to go.
No more slipping!
Posted on Feb 04, 2013
The blade does not tighten on the spindle and just spins freely. Even tightened down the center nut does not make a good connection to the blade.
There is a positioning "washer" that needs to be in place. If you don't line up the blade and position the washer it will not tighten. The blade will just spin around. Some even have a washer in front and in back. Be sure you have correct diameter of arbor that matches your blade too.
Feb 15, 2016 | Saws
Blade removal. Is the spindle right hand or left hand thread?
It is the opposite way to whichever way the blade spins. Rotation tightens the bolt. So if you put a socket wrench on the blade and hand turn the blade in the direction of travel, this would tighten. Lock the blade and turn the wrench the other way.
Long time since I have used a circular saw!
Jan 18, 2016 | Saws
Why can't the screw be tightened?
First of all, the blade has to be seated correctly on the spindle and the screw hand tightened to hold it in place. Next, a locking device such as a screwdriver has to be inserted crosswise between two teeth to prevent the blade from rotating. With the blade locked, the screw can be tightened. Finally, be sure to remove the locking device before operating the saw.
Oct 05, 2015 | Saws
Loss of power when blades engaded.
Remove deck belt from blade pulleys and Tri to spin blades by hand. If they don't spin freely, you probably need new spindle bearings but if you do need a new spindle I would replace the whole spindle housing... Just make sure the one (s) you buy has housing, spindle, bearings, nut and washer.
Jul 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to change the spindles on model 917.273220 craftsman tractor
The job is much easier and safer with compressed air and an impact. I would try really hard to find someone with air to borrow but if no air is available then wedge a piece of 4x4 between the blade and deck to keep the blade from spinning. BEWARE, the board can pop out and the spinning blade can be dangerous. Remove the deck from the unit. Remove the pulley first, hold the blade with your hand ( only if you have air/ impact) to prevent the spindle from spinning. Note the washer under the pulley. Then remove the blade, then the spindle bolts. Most AYP replacement spindles now come pretapped but if not place spindle in a vice and use one of the old spindle bolts ( they are self tapping) to make threads in the mounting holes. Then mount the new spindle in reverse order being sure to instal the washer between the spindle housing and the pulley. Again hold the blade with one hand and securely tighten the pulley nut with an impact. Also the unit probably has a blade brake arm and the spring holder is mounted by one of the spindle mounting bolts. Pay attention to its positioning before removal. If you have a heavy duty replacement spindle the notch on the bracket may not fit the new spindle. with a file or grinding wheel enlarge the notch on the bracket to fit.
Nov 25, 2012 | Craftsman Garden
The blade on my B&D sawcat spins even with nut tightened. cold it be the blade is worn, but i put a new blade on and it doesnt spin as freely but still spins
Hole in the blade is greater than spindle on the saw, you did not put bush washer/reducer in, or if that bit is correct, you are puting holding nut wrong way in.
Do not use saw till you rectify the problem, switch off the saw, remove power cord from socket.
1. raise saw table up for maximum cut
2. retract slide-in protector to maximum
3. remove nut from spindle, following by blade (and bush if used)
4. check internalholding washer if it is correctly inserted.
5. orient correctly internal washer (it have notch or notches and will go freely only one way - check if that is the case)
6. insert blade, with reducing bush if required
7. if external washer is used put it in
8. screw in the holding nut, hand tighten and check mobility of the blade, tighten up about 1/8 to 1/4 turn with spanner, this should be sufficient to hold blade in place without any slipage. If slipage is still present, you are doing something wrong, you need then to supply me with exact model and I will describe exact part look and order in which they must go in.
9. connect to electrical outlet
10. short switch on and off
11. check blade for wandering and slipage, if none then make test cut
12. use as usual if 11 is correct
Hope this will solve your problem :-)
Aug 16, 2010 | Saws
Blade won't spin
Check the blade with it off the base and make sure that it spins freely. Check the spindle on the base and see if it feels hard to turn. If the spindle turns too easy , then the connection inside the base is broken and needs replacing.
May 02, 2010 | Blenders
How do I disengage the drive shafts to tighten a
should be a black button between the handle and the guard. Spin the blade until it depresses all the way down and you should be able to loosen the blade.
Dec 05, 2009 | Ryobi P501 18v Circular Saw Only
My Swisher Rough Cut 12.5 HP 44 Inch mower - The blades stop cutting when I hit a dense patch of grass. The belt and the pully are still moving at normal speed but the blade slows. Also I can spin the...
I dont believe there is a shear pin on your blade spindles, what I have found on these machines is the the spindle nuts on the balde spindles sometimes loosen or wear and no longer squeeze the pulley on the blade spindle. To make this process easy on your self you need to tighten these with a impact wrench. However if you dont have access to a impact wrench you can use hand tools and block the blades you are trying to tighten with a wooden block. Just make sure you block the blade you are trying to tighten
Aug 13, 2009 | Swisher 44-Inch 12.5 HP Trailcutter...
Saws Logo
442 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
