Question about Dell Latitude C400 Notebook
My dell c400 will not boot windows. it tries then goes to the screen to ask to boot in safe mode. will not boot in safe mode. run diagnostics and it passes everything. any ideas
  • Tracy Cannon Jun 05, 2010
    My c400 does not have a disk or cd drive and i do not have a docking station.
    My c400 does not have a disket or a cd/dvd drive. I also do not have a docking station
    Sergeant:
  • 233 Answers
If you have windows xp with system restore enabled you can do system restore manually (for experts only ) or put you installation windows xp cd , boot from it then install windows again overwrite the old one using repaire option
Posted on Jun 04, 2010
  • 4,281 Answers
You need to repair your windows system files.
For that you need windows disk recovery disk.
If you don't have windows disk then buy it from nmearest computer shop.
It is very useful for your computer life.
Insert that disk into cd/dvd rom then when you power up the computer press F1 or F2 or del or ALT + F2 key to enter in bios .
then go to boot menu and st first boot device as cd.dvd rom then save settings and exit.
Then it boot from disk then follow the procedure and press any key to boot from cd..
Then wait for 5 minutes then you can see scren to choose option choose R for enter in recovery console then type in prompt "chkdsk /r" then press enter.
Then it fix and recover error on harddrive.
Then restart computer and again boot with disk then this time choose R for repair previous windoiws then it repair old windows then you can get back your windows.
Let me know if you need further assistance.
Thanks for using FixYa.
My dell inspiron freezes on the welcome page
While there are a number of possible solutions which may or may not work depending on several factors, the easiest to try is to boot to safe mode and run a system restore.
To boot to safe mode:
When you start the system, as soon as the blue dell logo goes away, tap the f8 button. This should get you to a menu from which you can choose "safe mode". It will show a bunch of writing on the screen and should eventually bring you to the login page, login as administrator.
Run system restore:
This varies depending on which version of windows you are running. In XP it is start>all programs>accessories>system tools>system restore.
Other things you can try:
Login as a different user.
Use start>run>msconfig from safe mode to disable startup items which may be causing the problem.
Consider removing recently installed software which may have caused the problem.
Scan for viruses, malware, spyware, ect.
Run diagnostics on the system by pressing f12 on the dell logo and chosing diagnostics.
The worst case scenario to fix a problem like this is reinstalling windows.
Feb 27, 2011 | Dell Inspiron 1525 Notebook
My Dell deskop when turned on only goes to the Dell slash screen then the screen goes black. Will not go to the windows screen.
Try these options:
1. Reseat your hard drive - unplug the ide cable from the motherboard and plug it again
2. Reseat the memory - remove and put it back again
3. Try to go to safe mode - while starting, press the F8 key to see the options
4. On the otherhand, you can select boot from the cd and use your Dell Diagnostic Utility and run hardware tests and see whats wrong..
Dec 01, 2010 | Dell Dimension 4500 PC Desktop
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
When i start up my dell inspirion 6000 laptop the logo comes up and then screen goes black
When you see the Dell logo, it means the system is booting and you see the splash screen that is generated on the motherboard.
Apparently this is where it is stopping.
Here's what I would do: First when you boot the computer, press F12 to get the boot options. Choose the diagnostics and run the system diagnostics.
You can also try to press F8 to get the computer into safe mode, but I'm thinking if you see nothing other than the splash screen, that may not work. If you are presented with Windows boot options, choose safe mode and do a system restore.
The last thing you can do if you have the Dell system recovery disk is try to do a repair from that CD if it allows you to do so.
Nov 06, 2009 | Dell Inspiron 6000 Notebook
Dell latiyude C400
The system is in a reboot loop. Possible causes are:
Corrupt installation of Windows
Bad Hard Drive
Bad RAM
Bad Motherboard.
Try booting to the Windows XP CD, see if you can access recovery console and run CHKDSK /R If that doesn't resolve, boot to the resource CD, and run diagnostics on the HDD
If you can't, boot to the XP CD or Resource CD, try removing the HDD and booting to the CD. If the system boots then, the HDD is most likely bad.
If you can't boot to any device, try RAM modules individually, see if system boots with only 1 module installed. If no change, then motherboard is bad. On a system this age, I do not recommend replacing a motherboard as it is not cost effective
Jun 22, 2009 | Dell Latitude C400 Notebook
I NEED PASSWORD FOR BOOT IN MI NOTEBOOK
This is a "security" feature to prevent stolen notebook computers from being used. I hope that you "registered" your computer with DELL after you purchased it. With your original purchase receipt, and your DELL product tag, contact DELL, and they will assist.
Jun 04, 2009 | Dell Latitude C400 Notebook
Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Mar 15, 2009 | Dell Latitude D600 Notebook
Dell c400 upgraded to xp now it won't boot up
you have toboot xp in the dell they are not interchangable you have load xp withit inthe dell or the dell wont work
sorry to be the bearer of bad news
Dec 21, 2008 | Dell AMD 386/33 Desktop Computer 333S/L...
Screen goes blank soon after switching on
Try "Safe Mode" (holding F8 key on boot and selecting "Save Mode"), then run diagnostics and an up to date (virus definitions) Anti-Virus full scan.
If Safe Mode is not accessible then you may want to consider a format and clean install by booting to your Windows (?) CD.
Sep 06, 2008 | Dell Inspiron 1300 Notebook
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
Dell Latitude C400 Notebook Logo
285 people viewed this question
Alun Cox
