Question about Intel Computers & Internet
I have a problem to connect F_AUDIO1:front panel audio header with my mercury pi945gcm mainbord. pin signal 1 PORT1L 2 GND 3 PORT1R 4 PRESENCE# 5 PORT2R 6 Sense1_return 7 SENSE_SEND 8 KEY 9 PORT2L 10 Sense2_return and the case has 4pin is MIC IN(R) + GND = PIN_NO 1 MIC POWER(L) = PIN_N0 2 LINE OUT FR + LINE OUT RR = PIN_NO 3 LINE OUT FL + LINE OUT RL = PIN_NO 4 SO , SIR PLEASE TELL ME HOW CAN I DO TO CONNECT THIS ARE PIN IN MY MAINBORD
    Champion:
  • 253 Answers
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
Hi ,, i have just fitted a intel d845gvsrb in my pc but i am not sure where the tower speaker wire , reset sw , power sw , power led , h h d led and the black single one go`s can you please help me ..
The Picture below shows you the locations of the places to put those wires are in relation to your motherboard. In yellow is the power switch and such. and the audio connection is in red.
The Pin layout for the power and other connector are as follows:
the layout for the audio header is as follows: avatar23454_8.jpg
To install the cable that connects a front panel audio solution to the front panel audio header, follow these steps:
  1. Turn off all peripheral devices connected to the computer. Turn off the computer and disconnect the AC power cord.
  2. Locate the front panel audio header (J8A1).
  3. Remove the three jumpers from the header (this disables the back panel audio connectors).
  4. Install a correctly keyed and shielded front panel audio cable.
  5. Connect the audio cable to the front panel audio solution.
To restore back panel operations follow these steps:
1. Remove the front panel audio cable. 2. Install a jumper on pins 5-6 (rear R channel). 3. Install a jumper on pins 9-10 (rear L channel). 4. Install a jumper on pins 1-2 (mic). 5. Replace the cover.
Apr 17, 2011 | Intel D845GVSR Motherboard
I HAVE A NEW CASE, & NEED TO CONNECT THE FRONT UBB & AUDIO LEADS. CAN YOU HELP, CHEERS
Hi there, first check the image below. You've got USB 3 and 4, and AUDIO section. For the USB, pins 1 and 2 represent front panel USB power on both 3 and 4. As for AUDIO connection, pin 1 is Front Panel Microphone input signal, pin 3 is Microphone Power, pins 5 and 6 are for Right Channel audio signal to Front Panel and pins 9 and 10 are for Left Channel audio signal to Front Panel.
You can find more details in the motherboard's manual, page 23 and 24.
Jan 23, 2011 | EliteGroup P4M800PRO-M478 Motherboard
I switched gabinets and the new one has a audio and mic imput on the front and i need to connect them the the MB corectly and idk where to plug them
The PCChips support page for your board is here, where you can download the full manual as well as drivers or other information you may need. This picture shows the front panel audio header location (AUDIO1):
And here is the pin information:
I believe the header complies with standard layout, so the plug on the cable to the front panel audio connectors on your new case may fit as-is. Or on many cases the wires have individual connectors on the ends to push over the pins. If yours is like this, you can put them on the correct pins by following the table. The wires are marked with their functions.
Good luck and thanks for using Fixya!
Dec 15, 2010 | Chips M863G V1.5 Motherboard
How to connect front panel connectors to front panel headers on a mercury PI945GCM motherboard...?
Kumar,
I use to Google it. Seriously I just typed in the manufacture Mercury and the part # P1945GCM, Motherboard and I got information. try it
Let us know if it helped
regards,
Digital Denizen
Nov 26, 2010 | Mercury Computers & Internet
Problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Aug 10, 2008 | ASUS P5VD2-MX SE Motherboard
Where is the audio output to front napel?
The ECS page is here;
http://www.ecs.com.tw/
Enter your model number in the search box and you'll be able to download the manual, which has the info you want.
Oct 15, 2007 | EliteGroup PT800CE-A Motherboard
Computers & Internet Logo
991 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
