Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Electric trips out when machine switched on - Hotpoint Aquarius WD640 Front Load Washer/Dryer
  • 416 Answers
Ok, it may be best not to use that machine until you have upgraded it to its proper breaker. From what you said, the lights in the house experience a voltage drop when the machine is on. This can only mean one thing, they are on the same breaker. The breaker will have 4 inputs, where to two outer ones will provide the 240 volts needed by your machine. If you have a multimeter or voltmeter, check the outlets for the 240v range for the washer, and 120v for the outlets in the vacinity and any other rooms where the lights may dim. the possibility still reamins that the house is just old and the wiring is bad. then that would be a rather expensive fix. Idealy you want your washer and dryer on a breaker together, but seperate from everything else. A high quality breaker goes for $20, cheap ones are $8. Also, when touching the breaker, make sure it is flipped to the off possition, i have personaly felt the grasp of those connectors many times and believe me, it will wake you up.
Posted on Jun 04, 2010
My washing machine trips the electric
take out the plug
remove the motor
now clean it ??
check the brushes or replace them if worn
or if you do not do this a new motor will be needed
as the motor safety switch will get blown
Feb 03, 2014 | Bosch Washing Machines
When we switch the dishwasher on it trips the electricity. It's worked fine for 2 years but now won't work at all and just trips the electricity.
Your dishwasher has a serious electrical safety fault which is causing the protective breaker to trip (although it may have a simple and cheap cause). With all due respect, your question clearly demonstrates that you lack the knowledge and skills to carry out a diagnosis and a safe repair (especially vital for anything which uses water and electricity). Before doing anything else, fully disconnect your machine from the main electricity supply by either unplugging it or for a machine connected to a flex outlet by turning off the wall switch and then removing the fuse.
Sorry, but in this instance you only have two choices: get a qualified dishwasher repair engineer in or replace the machine. Anything else could be lethal.
Oct 08, 2010 | Beko Dishwashers
My washing machine it tripping the mains board out, changes plugs and sockets and its still doing it - any ideas? perhaps the bushes?
sounds like water is getting into the electrics....or your trip circuit has became week...try switching the trip switch from another circuit.
Jul 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint 9537 washing machine tripping electric
You have a problem with Live feed shorting to earth on a main component. You need to switch off machine and seek a qualified electrician ASAP
Sep 03, 2009 | Washing Machines
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Oct 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryer tripping electricity saftey switch
You probably have a shorted heating element.
May 15, 2007 | Miele T1322C Electric Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
107 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
