Question about Home
Every time i turn the shower on it tripps the electric
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
If you mean it trips the breaker in the breaker box for the house you have a dangerous problem going on.is the shower system a newr fancy one with any pumps for the water etc? in that case it may be a bad pump. if not then you may be getting water into the electrical system somehow and you need an electrician to look into it right away. one other option is does turning on the shower activate any lighting fixtures in the bath? if so then that may be the source but you still need an electrician to service the system asap. dont use the shower anymore until you get it checked out.
Posted on Jun 04, 2010
Why would my malber WD 1000 keep tripping the breaker during drying cycle
breaker tripping is caused by an overload ( amps x voltage = watts). If the breaker is- for example -10 amperes and the voltage is 120 volts it equals 1,200 watts of power consumption and if the device is pulling more than the 10 amps setting of the breaker then, it will tripp. Just check how many amps is used by the device and if it is hooked to an electrical outlet that has a lower amps rating than the device then, it will tripp. Look for another electrical outlet that will support the device amps usage and give it a try to find if it does not tripp. If it still does then you may need to take it to a rapair facility to verify if there is any short within the device
Sep 20, 2015 | Malber Washing Machines
I need a manual for Tripp lite omniplus 1000 lcd
Changing the battery
If your Tripp LIte Omni 1000 LCD display a fault icon and beeps after changing the battery, try the advice given by the buzzerman which worked perfect in this case:
1. Turn the UPS on. Press and hold the ON/OFF button for one second.
2. Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until beeps several times). The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound. At the end of this process the fault icon and the beeping turned off.
Feb 15, 2012 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
APC Smart UPS system tripps mains electricity when i connect. Please help
UPS MOV is blown, change MOV or input filter circuit. or better send it to APC authorized service center.
Nov 23, 2011 | APC Matrix-UPS 5000 UPS System
Have a mira sports shower. when i turn on at isolated switch light comes on but when i turn on shower light goes out. no sound of water coming to unit or electrical sound in unit.
Have you checked if when turning on the shower water the electrical trip switch turns off at the fuse board. If the shower does keep tripping the RCD then the shower is the problem.
Apr 01, 2011 | Home
Turned on a triton trance electric shower it was working ok then it stopped coming out of the shower head and coming out of the overflow pipe at the bottom of the shower unit
The overflow pipe is a pressure relief device which is a small rubber ball that get's ejected when the water pressure inside the shower is too high. You will need to get a spare part to replace this. These generally operate because the showerhose is in poor condition and has collapsed internally, or the showerhead has become clogged up so check these things first.
Good luck.
Sep 21, 2009 | Kitchen Appliances - Others
Can't get my Tripp Lite INternett Office 700 working
You need to look at the batteries..in order for the unit to turn on..the batteries have to be significantly charged up ...measure the batteries with a voltmeter with the unit unplugged...they should be roughly 12.5 to 13.5 volts...if not..you need new batteries
Jan 03, 2009 | Tripp Lite Internet Office 700 (DHIO700)...
Electric shower is not getting hot
Locate your electrical panel box, find the breaker for the water heater, turn it off then back on, locate the water heater. Fins the powere disconect. Sometimes they are a simple pull disconect or switch, sometimes they are another breaker or fuse.
Check the fuses or flip the breaker if aplicable.
Do you have a volt/ohm meter?
Dec 06, 2008 | Home
MY Triton T90si electric shower continues to run when it is turned off. It is not fully on , but water keeps coming from the shower head evev when the electric isolation swithc has been turned off. Also it...
Most conventional showers have brass seats or rubber seats that can deteriorate over time. these will leak or dribble and not maintain your temp.. Rubber and brass seats are a fairly common and easy replacement. It sure beats trying to rip out a shower valve.
Jul 11, 2008 | Heating & Cooling
Electric dryer wont heat or turn off
there could be a temperature switch that tripps off. look at the diagram and trace also the power to the timer motor. it seems that you lost your power to your timer motor that is why the timer stays @ what ever setting you set it.
Feb 11, 2008 | Kenmore 63942 Dryer
Home Logo
116 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
