Question about Sony Cyber-shot DSC-W130 Digital Camera
When i power on it the lense moving continueously and display the message turn power off and then try again latter what can i do?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 04, 2010
Ink system has failed. Unable to copy. Refer to printer Documentation. Error 0xc18a0101
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
If this reset won't work ...open the front door ..and move the carriage to look for any paper left from a previous jam or so ...Make sure there is nothing blocking the ink carriage ..and than close the door and make the reset again ..
print a calibration if it asking for ..
BY the way ...it may be a good idea to reinstall the software again too ..
If this will not work ..try this ..:
A. - Press and hold the "*" key.
B. - Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
C. - Press and release in sequence the "1", "2" and "3" buttons
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS".
Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
If it shows improper shut down ..press on to shut down ..
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
message: "welcome to photo-smart express"
Using the Power Button, please turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Now plug the power cable into the wall outlet first and then into the back of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Print the report and if it is all OK ..it will work ..
Jul 29, 2011 | HP Photosmart 3210 Printer
Sony Cyber-Shot DSC S90 lens problem - fix or buy new?
its better to replace a new one than to repair it and besides you will cost alot if you decide to repair it. although if the cost is not that much then go for repairing it.
CHARCOIS
Aug 27, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
States scanner failer; turn off ;then on; have
Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the product control panel. While the product is making the copy, lift the scanner lid slightly to see if the scanner light is visible. CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
  • If the scanner mechanism moves across the scan bed, but the light is not lit, proceed to Solution six: Service the product .
  • If the light is lit, proceed to the next solution.
Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
  1. Make sure that the part number on the power supply matches the part number listed in the User Guide .
  2. Disconnect the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the copy job is successful, you do not need to continue troubleshooting.
      NOTE: Power strips and surge suppressors can sometimes prevent enough voltage from reaching the product.
  4. If the error message displays again, temporarily move the product to a different room, or plug the power cord into a different wall outlet.
  5. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the error message displays again, proceed to the next solution.
Solution four: Perform a power cycle
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then connect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the productFollow these steps to reset the product. Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
Solution six: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 26, 2010 | HP OfficeJet 7410 All-In-One InkJet...
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Scanner failure
Solution five: Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
call in to hp at 1800-474-6836 and since this is a hardware issue directly tell the agent you would like an upgrade if you decide to get it.
It will have a 50% discount on the upgrade printer for you with hardware and software covered by a one year warranty which you can extend upto 3 years on the spot
Jun 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
FEE message in display when using 50mm lense
The FEE message indicates that the lens is not set to smallest aperture (highest number). The camera body expects this so it will have full control of the aperture. It sounds like you may be accidentally bumping or turning the aperture ring on the lens while using it or changing lenses. There is a little slide lock to lock it at f/22 to prevent this. Turn the aperture ring to 22 and move the slider so the white dot is next to the orange mark on the lens barrel.
Feb 28, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
I can't turn my camera on,I press the power button,it gives me a whirling noise,the lenses come out(but not all the way),the picture on the screen is blurry,and I can't make a shot,and after2 seconds the...
The camera may be faulty or it needs to be reset to the factory settings.
Try removing the battery leave it out for at least 1/2 hour, then replace the battery.
If it doesn't work then you need a new camera.
Nov 27, 2008 | Olympus Stylus 700 / 700 Digital Camera
Error C:13:10, displays ''access'', ''turn the power off and on agai
Lens jams can happen without dropping the camera. The lens motor is bad, or a grain of sand has got stuck in one of the lens cogs. Either way will need lens repair/replacement.
Nov 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
DSC W80.
Whenever you switch on the camera the lense comes out to a certain places, stops and the camera is initialized to take the picture. In some cases when there is a friction in the movement of the lense, it does not comes out fully up to the proper position. so the camera mechanism draws it back and again pushes it out. this happens 3-4 times and if still the lense does not reaches its position it displays "turn the power off and on again" and the problem continues.
Your camera needs a repair of the lense assembly.
Jul 08, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Apr 15, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Sony Cyber-shot DSC-W130 Digital Camera Logo
373 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
