Whirlpool WF665/1 clunking/grinding
Have a Whirlpool WF665/1 front loader that makes a loud clunking/grinding noise during any agitating and spinning during a cycle. Only had the capacitor replaced today (04/06/10) because it stopped spinning all together. Now the capacitor has been fixed it still clunks and grinds during cycle. What could it be?
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Could be worn drum bearings.
Posted on Jun 04, 2010
  • KEN MARSHALL
    KEN MARSHALL Nov 01, 2013
    SAME PROBLEM WITH NOISE AND NOT SPINNING
MY MACHINE WAS DOING THE NOISE THING TOOK APART THE FLYWHEEL IS SLIPPING ON THE SHAFT, WILL NEED TO SHIM WHEEL OR REPLACE, NOT SURE WERE TO GET AS THIS PART IS NOT LISTED ON PART SIGHTS
Posted on Nov 01, 2013
  • KEN MARSHALL
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Whirlpool Model #: WTW4800XQ making a loud grinding noise during or at end of spin cycle. Help!
I have a similar model (WTW4850XQ1) that was making a very loud grinding/screeching noise during the agitation and sometimes the spin cycle. I unplugged and turned it on its front to get underneath and exposed the motor/transmission unit. Took the cover off the belt drive assembly and my drive gear was loose. Simple tightening down of the nut was an easy fix for me. But some times those plastic gears between the drive pulley assembly and transmission crack or the teeth wear down (think it's called the CAM). That is a fairly cheap and easy fix as well ($35). Repair Clinic website has free videos on how to diagnose and fix issues and parts as well. Worth a look.
Jan 08, 2013 | Whirlpool WTW4800XQ Washer
Admiral Washer makes loud steady noise during spin cycle but washes clothes & completes cycle. Possible bearing problem?
If a front loader type, try lifting up on the drum. If it clunks and seems to move somewhat easily, it is probably the front bearing on drum rear support shaft--a major tear-down to replace. If a top loader, try tipping the basket (that spins) in several directions--if it makes clunking sounds, try removing the agitator and check the tub mounting bolts at the bottom center for tightness. If ok, tip the tub again and watch for movement. It may have a bad bearing below the tub at the center area. Remove the tub bolts and pull the tub out revealing the drive hub underneath. Don't know if you would have to drop the transmission to repair what you find. Good luck!
Mar 17, 2010 | Washing Machines
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
1,037 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
