7356 Scanner how do I connect the scanner as a stand alone scanner not connected to Xerox 8830 direct to computer so I can scan drawings into computer What software or drivers would i require
  • 4,281 Answers
For that connect your scanner to computer with usb cable.
You can download scanner driver from it's manufecturer web sites.
If it is kodak scanner then download driver from below link,.
Choose your model and os then you can download driver and software for your scanner.
Click here
If you have another scanner then you have to download it's driver from it's manufecturer web sites.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jun 11, 2010
How to scan to computer via USB?
If the scanner has a USB connection cord connect it directly to the PC and reboot the PC. It may then recognize the scanner and have a driver for it. If it is not recognized then you should download a driver for it from the manufacter's web site. Good Luck.
Mar 31, 2015 | Xerox Documate 3920 - Document Scanner
Xerox 8830 with 7356 scanner will not show the image scanned in recently scanned images folder on the AccXES retriever
Check your settings and make sure that the folder has not been moved to another location.
Sep 13, 2013 | Office Equipment & Supplies
The Xerox 8830 scanner fluorescent why does not shine?
In case Xerox 8830 scanner fluorescent does not shine the simpliest way try replace one or put this lamp on another working device and check if it work
May 09, 2012 | Office Equipment & Supplies
Xerox 8830 and a 7356. Scanner has a clock constantly and doesn't illuminate
Verify the scanner drive sistems,motor or the scanner home sensor .
Feb 08, 2012 | Office Equipment & Supplies
Hello Steffen, We have a 8830 scanner Synergix.
Hey Panos,
What are you trying to feed a paper roll or single sheets or are you telling me you cant feed the original to be scanned? Can you copy or print internal status pages from your Xerox?
But it sounds like thats not the problem as it isnt hooked up and your lappy as it dont have a serial port you only have USB...... but this is a network printer.... do you have a network or it is just a stand alone lappy?
So I guess.. stand alone lappy to Xerox.... you will need to network it... and if it just a stand alone lappy ie no network then you will need a non standard network cable called a crossover cable to go from scanner to lappy but you will also need to set up a network with them manually asigning IP's of each to be on the same network, then hooking with a crossover (normally red never blue) network cable, and you will also need the software installed on this lappy no matter which way we go
Spose you could try a serial to usb adaptor but they will have issues propally when trying to use that sort of interface on scanning, normally one has the print server that is an option on your scanner to interface with the likes of a laapy, so I dont think it would workor a good idea to go with an adaptor
Well come back with some more info because the more info you can give me about your problem the better i can understand it.. cheers
We are talking about one of these beastys.. User Manual
Cheers
Steve
Dec 16, 2011 | Xerox 8830 Copier
Drivers for copier and scanner xerox 8830
Hi
You can download 8830 drivers from http://www.xerox.com/digital-printing/large-format-printers/enus.html
you need to check the type of controller that is fitted to printer.
Look on the back at box where connections are terminated.
label should have (F5Y or CNG - N5T - HFT and others select which is fitted and operating system, other support documents are also found here.
Jan 24, 2011 | Xerox 8830 Copier
I have a Xerox 7356 Scanner which continually says: Not Ready on the display. Any suggestions on how to troubleshoot this problem or where to go on-line to research troubleshooting?
it is likely the lamp.
Easy fix.
Buy a new lamp at a good lamp supply store. Type F32T8 SPX41
Make sure the back plate is white and re-normalize the cameras.
If you get the "NOT READY" message only after you insert an original
then the problem is likely the motion sensor.
Oct 14, 2010 | Xerox 8830 Copier
I'm setting up a 8830 and a 7356. The scanner says ready but when I put in the paper it says not ready take out the paper. The 8830 has a code LL-22, is that something I can fix?
As far as the scanner insert a sheet to copy and when it says NOT READY instead of rolling the paper out the way you put it in, roll it forward until it comes out the back.
An LL-22 is a HV power supply error. Most of the time when I see this the corotron wires are contaminated by developer. You need to clean it with a vacuum.
Nov 25, 2009 | Xerox 8830 Copier
We have a Xerox M20 Copier/Scanner/Fax/Email which we have always used strictly as a copier. We need to use it as a scanner, to reduce paper in the office and access/share documents electronically. I...
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
Sep 22, 2008 | Xerox Office Equipment & Supplies
52 people viewed this question
jasbo
jasbo
