Question about Sony FD Trinitron WEGA KV-36HS420 36" TV
I have a sony kv-36hs20 that will not turn on it just clicks and the power lite flashes about three different codes i think thats what that means i worked in a tv shop yrs back and have a little experence
    President:
  • 1,961 Answers
Hello!since you have an experience in repair,try to have a voltage data on the circuits of your tv..check whether there is a supply output from the plyback secondary,does the heater of the picture tube is lit?if yes your plyback is working fine,,if not,check the horizontal output transistor for any leak,open or shorted.do it same to the regulator.if these two transistor is bad replace them..check also for any leak capacitors on your horizontal section.there might be a problem in there..same with the capacitors on the power supply section.If The plyback transformer is not switching replace the jungle ic.this ic generates the horizontal pulse to the plyback..good luck hope i helped you..
please rate my help.
Posted on Jun 04, 2010
Testimonial: "very fast and informative"
    Sergeant:
    Champion:
  • 431 Answers
Its the ic in pwr supply part#starting mz
Posted on Jun 14, 2010
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony wega kv-36hs20 will not turn on
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony vega kv-36hs20
Have just posted this - twice, elsewhere - I'm afraid the sets are getting old:
"I think you are either suffering from a failed power supply or the supply is cycling because of a 'downstream' problem that could be in the high voltage circuit. In each case, the blink count probably would tell you approximately where the problem is located but only a Sony tech will have access to the codes. After all, we are only mortals.  "
Aug 25, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Problems with Sony FD Trinitron WEGA KV-36HS20
The set is going in to the protect mode.
There are some components that have become thermo sensitive from age and use. After the defective parts come up to their operating temperature they go out of specs.
Most of the time this type of problem comes from the power supply. Sometimes it is from another board that is causing the shut down.
The fix is to start by replacing the power supply for a start. If there are still any faults, the tech will try the boards to zero in on the defective one. Once he locates the defective board, if it is not worth to service, he will leave the new board in the set.
This type of repair can be in the average range between $200 to the $500 range depending on the exact fault. This is providing that the fault is not inside of the screen itself.
Jerry G.
Jun 02, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Kv-36hs20
Have you tried disabling SVM (scan velocity modulation)? Often touted as a "feature" of TVs, it's a way of artificially making a picture appear sharp. Totally unnecessary. When SVM (sometimes called VM) is on, it can lead to some color bleeding around edges.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
chris
Mar 21, 2008 | Sony KV-27V40 27" TV
Sony KV-36HS20
Jan 28, 2008 | Sony KV-35S45 35" TV
Sony Trinitron KV-36HS20
I have this set also..
When you set up for an HD signal (1080i) it is broadcast in 16:9 which is a widescreen format. The Sony set is a 4:3 format (more of a square shape) which means the black bars at the top and bottom appear so that you get the widescreen 16:9 format to appear.
This is one of the main negatives I have about this set, however, I can't really complain as I have had it for 6 years and it works great.
I never knew about the other format until I got an HD receiver from my satellite dish provider last year.
Hope that helps explain it for you..
Jan 25, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Aug 06, 2007 | Sony KV-DR29M69 29" TV
Sony FD Trinitron WEGA KV-36HS420 36" TV Logo
449 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
