Question about JVC Televison & Video
My JVC Tv shows horizontal stripes on the whole screen ,would you help me to fix the problem . i have JVC TV 21'' slim ,model No-21sx18,i used it for one year.Last month it's capacitor was damaged /fired/ due to high voltage,then i used it for two weeks by changing the fuse only.Finally it fired and smokes for the second time when it was functioning.Then i took it to technical person and he changed the capacitor but the picture bcame blurred and all the screen covered with horizontal stripes.i tried to maintain the problem with different technicians but still the problem isnot solved/fixed,i need someone to help me to fix the problem.
SOURCE: lamp going out on jvc flat screen tv 52 inch,how do you change
Versed, you have to open the back panel (cover) to access the lamp. replacing is easy as soon as you can see it. loosen the mounting bolt and pull to unplug the lamp from the SMPS Lamp power supply. Thats it.
Posted on Dec 29, 2007
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I had a mass/earth cut and it does that on my screen. What I do is I plug it where the electricity is ok
Posted on Mar 03, 2008
jdbouncer
  • 72 Answers
SOURCE: Philips 32 LCD TV 32PF9541 Black Screen
Sounds like a temperature problem if it takes a while for the problem to happen there are several things u can try and figure it out yourself. 1. Remove the back cover of the tv and turn the tv on. 2. use a hair dryer and apply heat to various boards of the lcd (inverters, power supply and scaler) while applying heat to see what board reacts and makes the tv go dark. More than likely its a defective LCD panel and its just as easy to send it back and get a replacement TV.
Posted on May 02, 2008
SOURCE: Convergence Issues...
I've looked online for the STK392-560 ics and have seen a difference in price from $5.00 to $30.oo. Is there any difference, if so, what?
Thanks.
Posted on Nov 18, 2008
  • 10 Answers
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
Jvc lt-42pm30
Horizontal lines are usually caused by a bad LCD (screen)..
Sep 24, 2017 | JVC LT-42X579 42 in. LCD TV
My Jvc Slim TV shows stripes on the screen after changining burned capaciter due to over loded voltage
ok.lower down the screen adjustment of your plyback.there are two adjustment present on your plyback body.the upper adjustment is for the focus adjustment and the other one is for the screen adjustment.Turn it counter clockwise with the power of tv is on..
good luck hope i helped you..
please vote for my help..
Jun 03, 2010 | Televison & Video
Problem with JVC CRT TV (slim) with screen to have red color at the lower left (facing the TV) corner and a green color on the upper right corner of the screen. Sometimes while watching TV shows, the upper...
There is strong magnetic field around the TV. This may be due to the tower speakers or any portable radio kept close by.
Re orient the TV try switching OFF / ON at the intervals of 30 minutes. The built in auto de-gauser will correct the problem. In cable TV program if the picture is OK, nothing wrong in the TV.
Check with a different CD.
May 19, 2010 | JVC AV-21QMG3 21" TV
How to trouble shoot problem with JVC Slim TV with blue color on lower leftcorner and green on the upper right color? Also, the display using VideoInputs are not correct horizontal.. the Screen is tilted....
http://www.go-gddq.com/upload/2009_03/09032313026620.pdf
www.scribd.com/doc/.../Sanyo-TV-LCD-Training-Manual
www.scribd.com/.../JVC-LCD-FLAT-Television-LT26WX84-Service-Manual
www.scribd.com/.../282-29-JVC-HD-ILA-Basic-Model-Training-2007
These service and training manuals above show you how to troubleshoot and isolate any problem, and what to do about it, please have a look and download and use all the information, in the manuals and you will soon isolate your issue.
May 19, 2010 | Televison & Video
TV Screen Stripes
NOt very clear.....
Multiple stripes all over the screen? Vertical or horizontal?
If it's only like an inch vertical lines put a mark on the cabinet where exaclty the line is, turn off the TV then open the back, you'll see lots of ribbon wires (gold color) from the plasma panel it self going to buffer boards, using the mark find the closest ribbon wire where the line is showing then remove and clean the contacts, make sure to reseat it properly when putting it back otherwise you'll just add more lines or black bar on the screen if pins are not seating properly.
But do not be afraid if the lines get worst just turn the power off right away and reaset the ribbon wire till you get it correctly.
CAUTION;
DO NOT try to do this while the TV is on oherwise you'll burn COF (Chip on film) on the panel and you'll end up replacing the whole PDP.
Mar 08, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Akira tv 21 slim pure flat CT-21 CSL 5AT-TT ,SCREEN LUCKED
saya punya tv 21akira slim kadang hidup-mati semua tegangan drop tapi kadang bisa hidup normal
Jan 15, 2009 | Akira ILT-260W Television
Jvc hd-61z575 green and pink screen
I know exactly which 2 dollar part you need to replace. digital-dump@hotmail.com
Dec 21, 2008 | JVC HD-61Z575 61" Rear Projection...
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
TV screen dislay partial horizontal beam
you had a problem on vertical section of your tv, if can fix it ,change the 100/50 volts capisitor on .vertical section or else all capasitors in vertical section
Oct 07, 2008 | Televison & Video
Televison & Video Logo
90 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
