Question about Toshiba e-Studio163 Copier
My e-studio 163 copier indicate code error c44 and how can i clear the code
  • 30 Answers
Hi how are you this is jack (Jack_pak@hotmail.com)
your copier show error c44..
Dear you press 0 and 8 key simantenasly and On copier other hand.. copier panal show ..AJ.... after 1min AJ constand.. then you press 400 and Start key.. your copier show one value 5.or.6 or.7..every x.y.z ok.. Then you press 0 key and press intrept key.
COPIER REVERSE AJ MODE THEN OFF COPIER..
AND simple ON Copier.
DEAR PLEASE VOTE ME.
Thanks ,
Best Regards,
Posted on Aug 14, 2010
Testimonial: "it was perfect and many thanks"
  • Toshiba Expert
  • 414 Answers
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
Thanks
Best Regards
Posted on Aug 30, 2012
Toshiba copier
for e207 model, error code should be in C44, F14, and etc...
Assume your error is C43, check the fuser thermistor, clear the error using 08-400 = Any value => "0"
Oct 01, 2015 | Toshiba e-Studio 207 Copier
Error c44 studio
codes c43, c44, c45
problem with the fuser
thermistor review
thermal fuse
check connectors
Dec 05, 2013 | Toshiba e-Studio 35 Copier
Error codes and their meaning for Toshiba e-studio 181 copier
toshiba e-studio 181 is not working. It shows that cover is open symbol and tells the same and the printer is woken up. what to do to rectify it.pls
Apr 27, 2012 | Toshiba e-Studio 232 Black and White...
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
How to reset spanner indication in Toshiba e-studio 163
You will press clear/stop and 8 button simultaneous indicate the service code.. after solve the problem..
Jan 19, 2011 | Toshiba e-Studio163 Copier
How to solve a problem error code c44 e studio 163
C44 Abnormal fuser after abnormality judgment
1,2.3. Check the thermistors, IH control board, IH coil and LGC board
Check the above components following the procedure 1, 2 and 3 for [C41].
4. Clear the status counter
Change the current status counter value (08-400) “4” to “0” for [C43] and “5”, “7” or “9” to “0” for [C44], taking
the same procedure as that for [C41].
* The status counter value is as follows in the following cases. Change them to "0" respectively.
• The error occurred during warming-up: "4" or "5"
• The error occurred after the machine has become ready: "6"
• The temperature detected by the center thermistor is 230°C or higher: "9"
• The temperature detected by the side thermistor is 270°C or higher: "9"
Nov 23, 2009 | Toshiba e-Studio163 Copier
Sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Jul 20, 2009 | Toshiba e-Studio163 Copier
My Toshiba e studio 167 is showing a c44 error code. What should I do?
the c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
Jun 30, 2009 | Toshiba E-Studio167 Copier
Toshiba e-Studio163 Copier Logo
617 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
