Question about JVC HD-61Z575 61" Rear Projection HDTV-Ready Television
JVC HD 61Z575. Power on. Lamp is on (seen from rear heat vent). Picture doesn't display but bottom half of screen full width is texture pattern. Upper half of screen is "interference" pattern full width. Selfcheck shows Sync M NG. Tun NG5. IP NG2. S NG. AVSW NG4. RGB NG9. HDMI NG1. All others check OK. What's the issue? Cost to repair? Bought in 11/2004. Only replaced two lamps so far and the set has been great.
JigSaw007
  • 157 Answers
SOURCE: NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Posted on Aug 10, 2008
power supply might be out if replacement lamp does not fix the issue QAL0765-001 light ballace
Posted on Sep 25, 2008
SOURCE: JVC HD-527575 problem
We just had the same problem. The Projector lamp is burned out. You can get the lamp at Electrified.com. Their phone # is 800-678-8585
Posted on Oct 22, 2008
mistersony
  • 320 Answers
SOURCE: Gray spots on screen on a JVC HDILA model HD 56G 787
Spots on the screen/picture can be caused by three things. Dust on the inside of the screen, on the mirror or in the light engine or optical block. The first two can be corrected by you if you can gain access to the interior. If it is the third (light engine. it will require a technician. If this answered your question, please be sure to rate the answer. Thanks!
Posted on Oct 31, 2008
SOURCE: my jvc hd-56g886
replace the lamp
Posted on Nov 04, 2008
No picture just black screen
sounds like the lamp went out in it. change lamp and u should get sound and picture
Apr 23, 2013 | JVC HD-52G886 52" Rear Projection HDTV
Replaced lamp in my HD 61Z575, but when I turn on my TV, nothing happens (no fan noise). After ~10 seconds, the Light LED starts blinking rapidly. Could it possibly be the brand new lamp? Ballast?
The old lamp was in there before the fan work?U replaced the lamp u put the door back on did u make sure the safety latch is off and tightly closed with the the lamp door.The continue blinking LED light does it make alot of clicking noises too.Yes,then the Ballast board it is dead too.The Ballast board only job are to help the projection lamp to ignite to work.
Aug 27, 2011 | JVC HD-61Z575 61" Rear Projection...
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
Changed lamp in 61 inch jvc dlp and still can't get tv to turn on
Ballast board is what turns Lamp on and CK your Fans if Lamp Fan is defective TV willnot come on.
Dec 11, 2009 | JVC HD-61Z575 61" Rear Projection...
Dark picture on 62" lcd
how old is the lamp , if is about a year old need a newone
May 12, 2009 | JVC HD-61Z575 61" Rear Projection...
Need owner's manual
Click JVC Support to download owner's manual of HD-61FH97 TV
Apr 13, 2009 | JVC HD-61Z575 61" Rear Projection...
Jvc hd-61z575 green and pink screen
I know exactly which 2 dollar part you need to replace. digital-dump@hotmail.com
Dec 21, 2008 | JVC HD-61Z575 61" Rear Projection...
Have flashing power light just replaced the lamp
make sure have put the door lamp on the right way ,
May 01, 2008 | JVC HD-61Z575 61" Rear Projection...
Green Tint on half of the screen
This is most likely a defect in the optical unit (about $1500.00 part). If out of warranty probably will just have to live with it. Those op units are also hard to get.
Jan 15, 2008 | JVC HD-61Z575 61" Rear Projection...
JVC HD-61Z575 61" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
