Question about Music
My HDMI output on TV keeps flickering on / off when connected via my Yamaha RX2700 amplifier. The signal initially works for about 20 x minutes and then starts flickering. When the HDMI cable is connected directly to the TV, the signal works fine. I have tried both a Samsung and Sony DVD player. I have a HDMI version 1.3b cable. Could it be a ''handshake problem''? Would I need a higher spec cable? Please assist Andre
  • 105 Answers
Look for hdmi output in amp if it is rusty or dusty put a drop of cleaning oil in it and insert cable 10 times init and see if it works there is nothing wrong in cable as it works directly must be a connection problem due to dust or rust
Posted on Jun 04, 2010
The Fender Champion 100 has a Pre Out input. Can that be use to go to a PA system?
The Pre Out and PWR In for a method to insert an effects loop. The output signal from the Pre Out should be line level so you would not connect this to our microphone input on the PA, but preferably to a Line Level input otherwise you would overdrive the PA's input. When you connect the Pre Out, the 1/4" jack may interrupt the signal so you may lose output to the Champion's amplifier/speaker. If this happens, you need to have a return line with the same line level signal plugged into the AMP In to get your sound back on the amplifier itself.
Nov 03, 2017 | Fender Music
Marshall Amp Quit
According to the schematic, once the signal is initially amplified (also where the LED shows signal), the audio is sent to the send/return jacks (shown on pg3-C7). A quick test to see if audio exists at the insert point will require an insert cable. An insert cable can be a balanced 1/4" cable which splits out to two mono 1/4" connectors or a pair of RCA's. Connect one of the insert outputs to a console (if 1/4" cable) or a tape loop on a home stereo receiver (if send cable splits out to RCA's) and see if you've got sound when playing your guitar (with LED on the Marshall showing signal). If no sound, go to (A) below. If you have sound, go to (B) below.
(A) Ten pin connector labelled CON2 (shown on pg5-B1). Make sure connector is tightly seated and that the pins on the jack and the female connectors in the plug are clean and that good contact is being made.
(B) Twelve pin connector labelled CON1 (shown on pg5-B4). This is the DFX board - make sure this is tight and well seated.
According to the schematic there are voltages seen at several of the connection points previously mentioned. If you have a multimeter and are qualified and careful - check to make sure the voltages are present as shown.
If you're not qualified - meaning you have little or no experience - STOP and refer this repair to a qualified bench tech. They get paid to keep the magic smoke inside the amplifier. You may end up damaging things worse or even beyond repair or even damaging yourself.
Nov 12, 2013 | Marshall Amplification Marshall MG250DFX...
I want to purchase a behringer 15 band graphic equaliser and connect it to a numark 5000fx mixer via skytec pro600 power amp can you help.
The signal path to follow is explained below:
*Audio Source(Cd/LapTop/Ipod)output to,
*Numark 5000FX Input, Then master/main outputs go to,
*Behringer FBQ1502 Inputs, then outputs go to,
*Pro600 Power Amplifier Inputs, then power amp outputs hooked up with a speaker each side.
Hope this helps.
Nov 06, 2013 | Behringer FBQ1502 Ultragraph Pro Dual...
Input and/or Output for pedals not passing sound through
I will answer this assuming you have connected the inputs and outputs of both the pedals AND the amplifier/guitar properly. Double-check your connections! ;)
Otherwise...Have you checked all the patch cables to make sure they're ALL working properly? That's usually the culprit in a situation like this, all other things being equal. Cables take the majority of abuse in your signal chain and also happen to be the weak link in the signal chain as well. It only takes one bad patch cable in a series to interrupt the signal.
I would take a pedal with perfectly functioning inputs and outputs and use it to test each cable yer using. If you verify all the cables are in fact working properly (and you are 100% certain everything is connected correctly), that indicates there might be an issue with the pedalboard's onboard electronics. At the most simple, the "From Guitar" or the "To Pedal" or the "To Amplifier Input" jack might be bad. One or more them, in fact, but it only takes one to entirely interrupt that signal chain. The loop section is less straight-forward in that if one of the loops has a bad input or output jack, that shouldn't affect the overall signal chain, nor the inclusion of the other pedals in said signal chain.
So, I think it's one of three things:
1. The pedals, guitar, or amplifier are not properly connected;
2. You have a bad patch cable;
3. Something has gone wrong with the electronics onboard the pedalboard, and this will probably require service.
Hope that helps.
Johnny
Nov 30, 2017 | SKB Corporation Skb Ps-45 Professional...
Europower PMP5000, In the Front Panel there is a Main 1 & Main 2 output, can I connect both to 2 Amplifiers so I have four independent outputs or 2 Stereo outputs? Can I Use these two outputs + mon 1...
Yes, you can use both the main1 and main2. They are independently driven and please note that they are PSUEDO balanced drives... that is the cold side of the balanced line is NOT driven as a complement, but is merely returned to signal ground by a 120 ohm resistor. This CAN cause hum problems or noise pickup depending on the connected equipment and ground loops. Best to run this into amps/speakers thaat have TRUE balanced inputs and also keep the power source the same for all devices.
Nov 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Aux1 and 2 are not working...what is the fix on the emx5016cf yamaha board
You are NOT trying to drive speakers from the aux outputs are you? These are LINE outputs that should be using TRS balanced lines to either powered speakers or amplifiers. Often these are used for monitors. The monitoors MUST be powered versions or use external amplifier if the speakers are passive..
Apr 26, 2011 | Yamaha Emx 5016cf 16 Ch 2x500w Powerd...
The speaker connected to my Yamaha EMX 312 SC is not bringing out any sound when we use the microphones but the displays on the power mix shows there is activity.
Assuming that you have checked the speaker leads for broken connections and that you know the speakers themselves work okay (test with a different amp) and that you can hear sound on the headphone socket
  1. Check that you actually have the power amp switch in the right position for the outputs (monitor jacks or main neutrik/speakon sockets) that you are using (see page 25 of the manual)
  2. That your speakers are connected to the speaker outlets on the rear panel and not the 'main outputs' on the front panel, which are for use with a separate power amplifier
  3. Check the mute button is not in
  4. You have turned both the master volume controls up.
If none of the above solves the problem it is likely that the overload protection fuses on the amplifier output stage have blown and need replacing - take to a repairer
You can find the user's manual here
http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/emx512sc_en_om_d0.pdf
Feb 10, 2011 | Yamaha Emx312sc 12 Channel Stereo Powered...
How do I attach power amp to 1832 mixer
There are a number of configurations for a mixer like the 1832, the most common are PA system and Recording system. There are Main output jacks which carry the mix as summed in the main faders. These in a PA system would feed the pa amplifiers which drive the house speaker system for the audience. These connectors are XLR 3 pin type on the rear, intended for professional pa amplifiers which use balanced +4dbv line input level. Amplifier which have 3 pin XLR connectors for input signals can accept that high level signal. For home style HiFi amplifiers, the signal level is nominally -10DBv and balanced or unbalanced signal lines with 1/4in diameter phone plugs which are connected to the mixer by way of a second set of Main output connectors which are 1/4in phone jacks. Use whichever amplifier input level your amp has.
If you are not using it as a main PA house mixer, but using it for recording, the main output connectors go to a 2 channel recorder or computer sound card recorder. The power amp and your monitor speakers are connected to the connectors labeled "Control Room" (CTRL Rm). These output are useful for recording because the signal through the mixer can be monitored from several buses, Solo, main mix, selected by buttons provided. The buttons only affect the signal heard through the control room monitors, and not the main output which only sees the main mix so selecting "solo" does not interrupt the signal going to the recorder while the engineer in the control can be checking other signal paths through the board.
Jan 21, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Can I connect a Yamaha DGX-500 piano to an amplifier?
yes - use two RCA cables from the left and right audio output and connect it to the aux audio RCA inputs of an amplifier or receiver.
Dec 06, 2010 | Yamaha Full-Size Keyboard
My amp breaks up too much and sounds messy. I changed the tubes and resistors and it helped a little but didn't solve the problem. Could it be my speaker?
colearthur16, Only a slight chance of problem with your speaker. You will need to prove that all stages of amplification of the audio signal from input to output are not being driven into distortion (clipping) because of a bad DC power supply rail to the low level amplifiers or the high power "final" output amp! To prove this, you will need the help of an electronics technician who has access to a variable audio signal generator (amplitude and frequency) and a cheap 5 to 20 megahertz oscilloscope to view the amplified waveforms of the amplifier stages in the Fender Amp. Remember the following statement for the rest of your life!!! "All musicians who use electronic amplification to play musicial notes through speakers should have between 4 and 8 hours of classroom instruction on how typical amplifiers (tube and solid state) operate and how to troubleshoot them when they fail to perform to rated specifications!!!"
Cole, have the Fender amplifier (not the speaker) tested by a qualified technician to prove amp is not at fault!!! 12fixlouie
Nov 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Music Logo
461 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
