Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
WHAT ARE THE TIMMING MARKS ON A HONDA GX160 ENGINE
  • Anonymous Mar 29, 2014
    Engine timing mark honda accord 2002
I an not see a timing mark on the crankshaft gear to line up the cam gear any other method
Posted on Nov 23, 2012
2 Suggested Answers
  • 583 Answers
SOURCE: what are the timing marks for honda 5.5 gx160
they are marked on the gears arrow goes to dot
Posted on Aug 08, 2009
What is the proper level on the dip stick for the oil?
There should be an area on the stick with cross marks on it. Try to fill it to the upper part of that cross hatch section
Feb 27, 2015 | Pramac ES3000 Alternating Generator With...
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Jan 16, 2014 | 5.5 HP GX160 Engine
Honda gx160 qh26 wont start, backfires thorugh exhst, new plug, re&re carb,valves in. .006 ex. .008 , sos please
The Honda GX160 is a single-cylinder multipurpose engine, so it doesn't have a timing belt, fuel filter, or any other wires other than the single spark plug wire and a ground. I'm having the same trouble with my Honda GX160. Spark is good, compression feels a bit lacking though, I haven't measured it. I've heard that the carburetor might be the cause, either needing to be cleaned or replaced as a whole. Dunking it in CLR works wonders, and if that doesn't work, you could probably find a new carburetor pretty cheaply.
Mar 19, 2013 | Cars & Trucks
Slipped timing belt on a 2008 honda accord, should i have it repaired or the engine replaced?
Hi ,1st I would make sure the timing marks are lined up,if they are your most likely fine,if not get a new timming chain,line up the cam and crank timmind marks install the chain and start it ,if the m,arks stay lined up and runs ok your set.I'ts cheap and easy to do for just the price of a timming chain.See ya,Don
Mar 01, 2013 | 2008 Honda Accord
What is the valve clearance on a honda gx160
Valves are set at 0.15 intake and 0.20 exhaust (metric)
Jul 25, 2012 | 5.5 HP GX160 Engine
1994 honda civic, had a broken timing belt that was replaced by a mechanic and the car is not the same since then, it is very lazy struggling to drive since that time.
i'll bet the mechanic did not line the timing marks up correctly.....so cam and crank are not in sync.... i,ll almost guarantee it...
Jan 10, 2011 | Honda Civic Cars & Trucks
Were the timing mark are
Timing marks are located between the engine and tranny. There is a small opening, on the front of the tranny, at the bell housing where the timming marks are visible. It might have a rubber plug, in that opening, that pulls out for viewing the marks.
Oct 24, 2010 | 1990 Honda Prelude
Fitting timming belt to 95hondadomanivtec 15 valve
after aligning all the marks start from the bottom and route belt counter clockwise around ending at tensioner.
Aug 25, 2009 | Honda CRX Cars & Trucks
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
261 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
