Question about Western Digital My Book Home Edition 500 GB USB Hard Drive
I want to clear up my harddrive I have only 11% space
I have the WD my book home edition, Backed up my files number of back ups +2
, Is it safe for me to delete, documents, pictures,music from my harddrive (c:) or should I make a folder up to put them in, drag it into the WD harddrive then send docs, pics, music to the folder, or set up sub folders.
User manual wont explain that final step.............cheers.
Regards
Mr hangn in the air
    Problem Solver:
  • 10 Answers
Hard Disk Drive Cleanup this may be could help you
Posted on Jun 04, 2010
I have WD My Book Essential 2 capacity 500 GB. Unfortunately everytime I connect it to the PC and power, does not show as a hard drive and has no driver. I backed up my files on it from the same computer...
you may have a bad drive,but first dose the drive power up not just light up can you hear the drive.
what you have in the box is just a nornal HD in an external box. you can if "absolutely nessesary " remove the HD and put it into your PC as a second drive.
but first you need to know if it is running and if the WD My Book power supple is working.
Have you tried using a different USB cable? a different power supply of the same Voltage & amps.
Mar 25, 2011 | Western Digital My Book Essential Edition...
My wd 1000 gb external harddrive, when plugged into my lap top, the screen will only show all my songs and movies up to the letter p. i even tried it on another laptop and it did the same thing. now i hook...
you might need to create folders eg folder name a_to_f_files and copy the files the start their names from a to f and do the same for g to l with a folder named G_to_L
There is a limit on the number of files you can have in the root directory in Windows so by creating a folder you split it up and windows sees less files in one folder or in the root directory
Jan 08, 2018 | Western Digital My Book Home Edition 500...
I have a WD my book essentials 1.5tb usb HD. It says I have only 256 gb backed up but 1.1 tb of "other files" and is 98% full. Why is this?
How big is the WD Drive? It sounds like it is a 1.5 Tb Drive. If that is the case then it is reading correct. There are 256 GB of backed up system files which is mostly Windows and it backed up 1.1 Tb of Miscellaneous files which could be other non Windows Programs, saved files and internet junk.
Jul 16, 2010 | Western Digital Computers & Internet
My WD External Hard Drive Went From F To g aND i cANT aCCESS mY mUSIC i hAD bACKED uP, tHERE aRE sTILL fOLDERS oF tHE aRTISTS bUT nO fILES iNSIDE
Open "My Computer".
If you have some other USB device (camera?) connected as the 'F:' drive, then the WD drive, when connected, will become the next-available letter, namely 'G:'.
Run a 'Check-Disk' against the WD drive, to check the integrity of the file-system.
Apr 03, 2010 | Western Digital My Book Essential Edition...
I have a 500GB my book essential edition external harddrive and i am only able to access 10GB of my space, please help
while you only have 10 gig of space "used?" take what you have off the drive and use the disk that came with your WD MYBook and reformat the drive into "2" drives..........Depending what OS (operating software) you are using some have a limitation to show the correct amount this is why I would suggest that you split the drive into sections or just reformat and see what you get
Jan 26, 2010 | Western Digital My Book Essential Edition...
Clarification re WD My Book storage space issue
this happen to a cousins laptop the only way to get it to sort out was to format the drive.it sounds harsh but it was the only way.
Dec 06, 2009 | Western Digital WDH1Q5000N 500GB MyBook...
I recently reinstalled my OS (Windows XP Media center edition). Ever since i reloaded the OS my WD My Book Home edition 1TB external HDD stopped showing up in the windows explorer as a drive letter. The...
I can't diagnose the drive issue... but I can offer a reliable and trustworthy data recovery solution that I had to use a year ago. It's Seagate's do it yourself data recovery and will work on your WD drive. So if you can't resolve the issue otherwise, consider this as a recovery option...
https://services.seagate.com/diysoftware.aspx
Sep 24, 2009 | Western Digital MY BOOK HOME 1TB EXT...
New laptop wont recognize external hard drive files
What program was used to 'Back them Up"?
It may be an incompatibilty with Vista and you should contact the backup programes support arm to get a converted fix for Vista
Please rate our help to keep FREE service online
Aug 30, 2009 | Western Digital My Book Essential Edition...
Hi, I can't find my booklet but my elements powered by WD harddrive is now full. Do I delete everything on it and will it start to backup again. Because I keep getting something up on my computer telling...
If you clear/format the external and you have whatever program you are using to backup, it will start backing up again. Make sure you do not delete any critical files you have backed up before wiping it.
Jan 30, 2009 | Western Digital Elements powered by WD 320...
How do I get the files from the WD external (500 GB) to my computer
In this case the MOST effective way is to try some data recovery program to see if it can help rescue your data on your WD external.
Jul 24, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Home Edition 500 GB USB Hard Drive Logo
138 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
