Question about Kyocera Mita FS 9500DN Laser Printer
Service call F040:0000000 error displaying in kyocera 9520dn printer what could be the problem i replace fuser assy imaging drum, magnet roller assy, powder tank, still the problem is there and printer is not going to initializing.
Soulvisitor
  • 1113 Answers
SOURCE: Brother 8840 Fuser Roller Gear
You can buy the gear , I always just replace assembly to reduce possibility of later breakdown
you can Purchase gear or Fuser HERE
Posted on Dec 16, 2007
leroyal
  • 2120 Answers
SOURCE: Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Posted on Feb 25, 2009
  • 4090 Answers
SOURCE: wrinkling envelopes in FS-3900 Kyocera Printer.
try chaning the quality of the envelope, some do not respons well to heat.
Posted on Jun 23, 2009
kd6rhd56
  • 400 Answers
SOURCE: Paper goes through fuser assy ok. Jams at exit to
sounds like the fuzrd section of the motherboard has died, try geeksquad for service, and if not under warranty replace unit.
Posted on Oct 12, 2009
anantakumarj
  • 330 Answers
SOURCE: kyocera fs 9530 - f040 error
this error came because of the Defective harness between engine PWB and main PWB or improper connector insertion. open both board and re fix it and check ....... please mention your correct printer model in next comment so we will give you idea how to open the boards ....... restart your printer and check it ...........
Main - Engine controller PWBs communication
error
• The communication breakdown occurred
between main controller PWB
and engine controller PWB during 30
seconds.
cause
Defective engine controller PWB........Defective main controller PWB.
solution
Replace the engine controller PWB
Replace the main controller PWB
Posted on Dec 21, 2009
How to resit c6000 ofkm1635
enter service mode 1087,1087>check display ,select 163 , green button, cursor down on display and execute than green button, machine will reset and than restart. If problem comes back. replace FK-410 fuser assy.
Jul 29, 2014 | Kyocera Mita KM-1635 Copier Drum Unit...
Kyocera FS-1500 printer shows E4:171911 fault?
do you have manual, try to see troubleshooting section there it might be described.
Apr 26, 2008 | Office Equipment & Supplies
I have 5 Kyocera FS-3900DN laserprinters to repair. I've disassambled them. The only problem I've recognized the fuser rollers are run-down.The metal that can be seen in the rollers magnetizes...
I've never heard of anyone attempting what you describe, but I'm concerned that the new coating will not be even enough for a satisfactory print, even if the drum will function in the static retention.
Replacing the fuser is recommended:
http://www.redstartprinters.com/fk-320fuserunitfs-3900dn4000dnprintersfreegroundshipping.aspx
Sep 25, 2011 | Kyocera FS-3900DN Laser Printer
Copies and faxes double images how to solve
put an old or new toner cartridge in it to see if the double imaging goes away. If it is still there its the fuser. I can help you with that if you need supplies for the fuser. Steven 818-888-0006
Mar 05, 2010 | Canon imageCLASS D880 All-In-One Laser...
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Feb 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
The wheel at the end of the drum broke. mita machine #kt47. do I have to replace the drum? at least i think it's the drum,its the roller with wires attached at each end. the machine code # 199307
It sounds to me likeit is your fuser unit.
Depending on the model you can either replace the fuser drive gear or replace the entire fuser unit.
Get your local service agent to look at it
Jul 03, 2009 | Kyocera Mita Office Equipment & Supplies
Wrinkling envelopes in FS-3900 Kyocera Printer.
Jun 23, 2009 | Kyocera FS-3900DN Laser Printer
SHADOWING
usual problem for shadowing of copiers and printers that uses heater is the scratching of the teflon coating of heat rollers.
Mar 30, 2009 | Zebra Eltron LP 2824 Thermal Printer
Transfer roller assy is wearing out drums on rear side
You need to replace the two collars that lays on the left and right of the magnetic roller.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Feb 05, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera Mita FS 9500DN Laser Printer Logo
422 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
