Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Parts for panasonic pt-53tw53g
I was wondering if u knew the parts numbers for r7011 and r7015 they are 2 resistors i need to get. are they the same resistor or 2 different wattage/ohm? and do you have any recommendations on where to get said parts?
  • toolfreak316 Apr 29, 2008
    replaced both resistors. r7015 burnt up. would this be from bad solder or incorrect reconnection of cables? please help.
    Genius:
  • 1,694 Answers
R7011 = 2.2 ohm 2 w...
r7015 = being researched....
Partstore.com ...........................................T.
Posted on Apr 15, 2008
  • Vista Electronics Apr 29, 2008
    It is from cheap replacement IC's........use X 480293 kit
    bagged by Hitachi, IC's made by Sanyo = STK394-160E.
    They upgrade / sub STK392-110,120 and -150 in any brand...T.
Clean screen on a Panasonic tv model pt-53tw53g
https://elektrotanya.com/panasonic_pt-53tw53g-pt-56tw53g-difference-pt-53wx53g-parts-list.pdf/download.html
Feb 09, 2018 | Panasonic Televison & Video
R517 please give value, thank you model # PT-53TW53G D BOARD
R517 is a 10K ohm 1/4 watt carbon resistor part number ERDS2TJ103T
Jul 23, 2011 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53TW53G coverage wont move the blue color? I DON'T KNOW THE PROBLEM. I JUST REPLACE THE IC'S. pLEASE HELP
Did you check the six 2.2 ohm 2watt resistors? Usually your model will have at least one blown when the ICs fail
Nov 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
My panasonic TV Model: pt 53tw53g turns off by it self
My Panasonic has exactly the same problem. The repair man just came in and said that the convergence and resistor burned under heat and have to be replaced. Will cost $400.
May 13, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic TV projector PT 4743G
yes the convergence ics will blow that resistor
Jan 21, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic pt-53tw53g D board
You can get TNP2AH046S D Board at Panasonic Parts and price is approx $280
Sep 08, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Replaced 2 resistors one burnt up. please help
They would only burn if your convergence ICs are bad so if you didnt change the ICs with the resistors they will keep burning.
Apr 29, 2008 | Panasonic PT-53TW53 53" Rear Projection...
PT-53TW53 resistors needed
They are 2.2 ohms, 5%, 2 watts.
You can try digikey.com or radio shack.
Apr 11, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pt-53tw53g
It is a 2.2K ohm resistor, here is the info out of the service manual.
R7031
ERJ6GEYJ222V
RES M 2.2K-J-1/10W
hope this helps.
Apr 01, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
115 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
