Question about Sony Xplod XM-554ZR Car Audio Amplifier
Can i have box dimentions for my 12" xplod sub
    Novelist:
  • 149 Answers
  • Warranty Terms - Parts 1 year limited
  • Warranty Terms - Labor 1 year limited
  • Product Height 12"
  • Product Width 12"
  • Product Weight 7.8 lbs.
  • Product Depth 6-1/2"
  • Subwoofer Size 12"
  • Resistance (Ohms) 4 ohms
  • Bottom Mount Depth (inches) 10"
  • Woofer Composition Mica-reinforced woven glass fiber composite
  • Woofer Surround Rubber
  • Peak Power handling 1300W
  • RMS Power Range (Watts) 380
  • Cutout Diameter or Length (inches) 12"
  • Sensitivity 84dB
  • Frequency Response 30Hz - 1kHz
  • found at:::---- http://www.bestbuy.com/site/Sony+-+Xplod+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/9202481.p?id=1218057724056&skuId=9202481
Posted on Jun 04, 2010
800 watt mono block sony xplod amp blowing my dual coil 1500 watt subs
if the wiring to the sub is correct, then you have something wrong with the amp itself... something is power surging to the subs which is causing them to blow
Aug 25, 2012 | Car Audio & Video
My sony Xplod double sub box wires keep getting loose and stop working
are you just wiring them straight to the terminals or are you using conectors
Jul 25, 2012 | Sony Car Audio & Video
I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
May 28, 2010 | Sony XM-ZR1252 Car Audio Amplifier
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub box dimentions
12 " subs need 1.5 cubic feet sealed box...
Jul 17, 2009 | Volfenhag ZX-4812 Car Subwoofer
Amp often decides to not work.
HI DUDE ,, TRY CHECKING UR RCA CABLE ,, COZ IT MIGHT B UNPLUGED AT UR PRE AMP OR PLAYER ... OR CHECK UR SUB WOOFER WIRE INSIDE THE BOX ....
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Problem with amp?
Give that new sub a chance to "break in". New speakers require a few hours of use before the voice coil(s) and spider break in and began operating at their best performance. Is the box within the operating specs of the sub? Is this a ported box; if so you will here some turbulance type noise from the port. What type of distortion are you hearing? Alternator noise(dentist drill like sound) would only be noticable through a sub at lower volumes due to the frequency response of a sub. Is the amps lowpass crossover turned on?
Mar 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
NO SUB OUTPUT
The sub outputs are simply lowpass filtered preamp outputs for use with a subwoofer amplifier. They supply a lowpass filtered signal for a subamp or 'powered subwoofer" like a bazooka tube. Test your "basstube" for 12 volt input power and make sure the "sub" setting on the radio is turned up too.
Aug 26, 2007 | Sony XPlod CD Player w/MP3 Playback...
Sony Xplod XM-554ZR Car Audio Amplifier Logo
169 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
