Maytag ALW432RA Top Load Washer Logo
Posted on Jun 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine won't spin - Maytag ALW432RA Top Load Washer
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Jun 05, 2010
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10844370
Points
101584
If you are having a problem with your top load washer then check out this tip...
Washing Machinemachine won't spin - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Why does whillpool washing machine not want to spin
Is it a top loader? If so, the drum may be out of balance re-arrange the load so that it is about even all the way around and try again. or ..
Troubleshooting Washing Machine That Won Spin DoItYourself com
Why Won the Whirlpool Washer Spin or Drain
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
My kenmore ad 80 series washing machine won't spin
The lid switch is probably out. Bypass it and see if she magically comes to life. Their are 3 wires to the lid switch 2 of which are live wires. Jumper them 2 live wires and see if she runs in spin.
My home video: Washer won't spin It's a doozy
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
Washing machine won't rinse and the water won't drain out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
33helpful
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
2helpful
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having problems with your front load washing machine then checkout this tip...
heatman101
4helpful
My washer turn on but won,t spin
tub bearings may be frozen up. Can you move tub by hand?
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
