Question about Samsung WF338AAB 4.0 cu. ft. Front Load Steam Washer
Washer power off?
My washer power just when off on me i cant turn it back on what happen?
    Genius:
  • Samsung Master
  • 1,474 Answers
Try fuse in the plug..
Posted on Jun 04, 2010
My Samsung washer is throwing a code looks like a BE code how do I reset it. All I do is turn on the washer and in 20 second the code comes up with out touching anything
You can try plugging the washer from the outlet. Turn on the power knob on the washer for a couple seconds to release any stored power, then turn power knob off. Plug washer back in the wall outlet to see if this resets the code back to normal.
Apr 03, 2015 | Samsung Washing Machines
Wash machine LG wt5001cw won't turn on
I have a LG wt5001cw top loader washer and after it completed its cycle it shut off and will not turn back on. How do I fix it?
Jan 12, 2013 | LG WT5001CW Washer
Cant pull start the pressure washer
Turn water off to the pressure washer, release pressure by applying hand pressure to sprayer. After water pressure is released, turn water back on (should not have motor running without water.) then try to pull start.
Jun 18, 2011 | Honda Karcher G2400HH-R Pressure Washer
My maytage neptune washer is flashing PF what does that mean?
Hi
Error code PF means power failure. This happens when there is a power surge or the washer is unplugged manually. To reset this error you'll need to turn off the washer and unplug it for 10 minutes. Restart the washer and check, If the error still appears then pressing the Spin Speed key will begin the Board Output Test. This test turns ‘ON’ a specified output after a key press. Pressing the Spin Speed key again cancels the test. Please post back for further assistance if required.
Daniel
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
PLEASE HELP!
right could be your belt,casrbon brushes if the motor has these which you will notice they will have a wire going to a small plastic part on either side of your motor it will have 2 of these if these are worn down to about 8ml they need replacing if your washer does not have carbon brushes than it will have a small circuit board called a module if this is faulty sometimes cheaper to replace your washer
Aug 12, 2007 | GE WPGT9350C Top Load Washer
Good power, tub will not turn
tub, is the lid switch plugged in? If not take a jumper wire and jump out the two ends on the harness. Timer controls recirculation and spin. The motor turns both ways. The spin cycle goes through the lid switch. Catriver..post back
Feb 27, 2007 | Whirlpool LSQ8000 Top Load Washer
Samsung WF338AAB 4.0 cu. ft. Front Load Steam Washer Logo
239 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
