Question about HP Pavilion Media Center TV m7330n (ER101AA) PC Desktop
How do you install ram in hpmedia cnter m7330n
    Brigadier General:
  • 7,191 Answers
You can install a maximum of 4GB (4 x 1GB) RAM on your computer.
For detailed steps and procedures for adding a RAM module on your computer, kindly click here. You can also download and view the video instructions for adding or replacing the RAM by clicking this link
Kindly follow the installation instructions carefully and take the necessary precautions while installing the RAM.
Hope this solves your problem. Thanks for using FixYa.
Posted on Jun 04, 2010
HP Pavilion m7330n: Possible corrupt bios, solutions anyone?
what OS? is this XP? with SP3 or not? needs it. if XP.
you never need to delete old hdd, drivers ever.
reg booster?
would not reboot. the HDD fails>?
its not really BIOS, corruption at all,
if the CMOS battery is above 2.9v then no corruptions happen.!
the ROM part will not corrupt but the ram part can , easy, Battery.
check this battery any time bios forgets things this battery is the
no forget feature (CMOS NVRAM battery backup)
Bios can boot to any dvd, or cd, if you plug it and and select it.
BIos can boot the HDD, or SSD, or USB stick. and more, F9 key?
never use reg booster, avoid it like the plague,
any reg modifying programs are nothing but trouble. !!!
m7330n circa 2005. a desk top (or media center) Athlon 64 X2
so what DVD are you installing,
Sata, or PATA
tell what you have and why you need and adaptor,(btw i have them all here, from you name it ,to what eva.)
the HDD is SATA.
but what is the DVD jacked into?
dvd drives come in;
PATA
SATA
USB
what is yours?
May 06, 2017 | HP Pavilion Media Center TV m7330n...
At boot-up, HP Digital Media Archive pops up for no apparent reason. Cannot find a way to prevent it.
Have you tried using msconfig to see if it is listed under startup programs? If it is listed you can uncheck it and it will no longer load at start up.
Aug 13, 2011 | HP Pavilion Media Center TV m7330n...
I have an HP Media Center PC m7330n. It recently was infected with a host of viruses and rootkits. I eliminated all the viruses and rootkits with a battery of anti-virus programs. Everything works as...
You might want to try to go to the device manager and go to the Universal Serial Bus controllers
Try to uninstall everything and restart the computer.
See if that will let the computer recognise the USB ports.
If that does not work, you might want to reinstall the chipset drivers of your motherboard.
Hope this works for you.
Jun 21, 2011 | HP Pavilion Media Center TV m7330n...
I have a HPMedia Center PC. The MFC 5440cn does not appear to be compatible with it. Is this true?
I would be very surprise if your HP did not support Brother printers in general!
If you are running windows, including windows 7, you will find the required Windows drivers at Brother Solution Center web site.
The following official Brother site link will assist you:
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/model_top/colormfc/mfc5440cn_all.html?reg=eu&c=eu_ot&lang=en&prod=mfc5440cn_all
Hope it helps.
Dec 14, 2010 | Brother MFC-5440CN All-In-One InkJet...
My x3's software got corrupted..phone turns on,shows blank screen and switches off again.please help
HI, I THINK THERE IS NOTHING U CAN DO.GO TO NEARBY NOKIA MOBILE CARE CNTER AND INSTALL THE PHONE SOFTWARE.THEY WILL HELP...THANKS
Nov 18, 2010 | Nokia X3 Cell Phone
My HP Media Center m7330n won't power up... The fan comes on but will not boot.. The LED power light blinks at 3 second intervals from blue to yellow/orange.. What is the diagnosis...
You have to check with your RAM sir, if you know to remove the side cover of your CPU(tower) there will be a green colored chip fixed in vertical position in the motherboard if remove it and then fix it properly means you will get the display in yur screen.i will show you the RAM picture2f70f69.jpg
Oct 29, 2009 | HP Pavilion Media Center TV m7330n...
My HP media center edition m7330n desktop will not power up (won`t stay on), The power button light flashes every 2 seconds from blue to orange & no power at usb ports. Any advise on what went bad or...
Before doing anything try to get the following tested,Processor,Power supply,Memory,also remove any cards installed including modem.Look for physical damage(ie) Brown substance coming from capacitors on board all capacitors should be flat on top if they show rounding or a hump over the top the MotherBoard needs rplacing!
Aug 08, 2009 | HP Pavilion Media Center TV m7330n...
Computer beeps and fails to start
If there was recent hardware added to it or RAM then try removing it and boot up. You can try resetting the RAM. You can also check all cables and power within the case to make sure everything is connected properly. Listen for the fan on the PC, if the fan doesn't start up then it could be an overheated mother board. Beeps can mean a number of different things. If there's no error on the screen then it probably isn't getting further then the BIOS. I hope that helps.
Apr 06, 2009 | HP Pavilion a1410y (RB042AV) PC Desktop
Wireless bottom
the wireless setup is in you remote
Aug 30, 2008 | HP Pavilion Media Center TV m7330n...
Hp pavilion m7330n motherboard issue
The system in question requires motherboard model ms-7184 and can be found on ebay for less than $100.  If your repair guy used a different motherboard you will get the issues described and need to reinstall the OS.  It is impracticle to put any more than $200 in most desktop computers more than 2 years old, your repair guy should have advised you of this straight off.  Find a new person to take your equipment.
Jun 27, 2008 | HP Pavilion Media Center TV m7330n...
HP Pavilion Media Center TV m7330n (ER101AA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
