The picture is very red even when you turn the colour almost off to black and white there is a reddish tinge. It has been turning redder over time.
  • 8,617 Answers
Could be the Red CRT going on you or could be a problem with the red CRT circuit. Please let me know your model number and I should be able to help you diagnose the set properly
Posted on Apr 09, 2008
The color is all red.
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Jan 01, 2010 | Hitachi 51F500 51" Rear Projection...
Hitachi RP CRT Gone Red On All Inputs!!!
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
The colour on my TV is a reddish colour. Have tried the colour adjustment. Skin colours in particular.
simple. easy. you have 3 screen adjustments. red green blue. turn color all the way down. you should then get just a black and white picture, but in your case, it will still be reddish. behind the speaker grill is an access panel for screen adjustment. remove speaker grill. remove access panel. you will see a block assembly roughly 6 inches square with 6 knobs on it. 3 are for screen, 3 are for focus. adjust until you have a black and white picture. then go into menu and turn your color back up. enjoy!
Nov 14, 2009 | Televison & Video
What is this
objects depending on the ambient light (sun, fluorescent tube etc) tend to have a reddish to bluish tinge. white balance eliminates this colour distortion by ensuring that a perfectly white image is obtained at the video output when the camera is pointed at a reference perfectly white object.
'Auto white balance' simply means that the camera does this automatically.
rgds
Luwangula
Dec 03, 2008 | Panasonic NV-GS180EF-S Mini DV Digital...
Reddish tinged photos
It might be a possible CCD defect , as usually the symptoms are odd colours in a photo hence your red tinge in your photos.Its quite expensive as it labour intensive to fix .Rather just buy another camera or you can try to solder another ccd from anotehr camera > look on ebay for parts (not recommended precise alignment needed).
Sep 25, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Picture is turning red
I had the same problem, where the red CRT was shorted out. It kept on getting redder and redder until on day I turned in on and it was all red. CRT's can be pricey so it would be best to call a repair tech to diagnose the problem. Most will do in home service so you probably won't have to cart the tv somewhere. Once I replaced mine it's worked great ever since.
Aug 15, 2008 | Hitachi 51F59 51" HDTV Projection...
Picture washed out colour
I think you should change CRT of your TV
Sep 05, 2007 | Toshiba 65HX81 65" Rear Projection...
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
