I have HB ws824(3) telephone system (PBX). After finish a call (out going/ in comming) from line 1, still the system indicate that the line 1 "in use" (system indicating light). But not the key phone. At that time, if take a call to line 1, it says "user busy". Same for line 2, 3 and 4. If I use line 2 same thin with line 2 and so for line 3 or line 4.
  • lalith458 Jun 21, 2010
    Thank you very much for your advice.
    I done it. But, still the problem is there.
  • 821 Answers
Hello,all you need to do is to reset the phone.you can kindly get the reset mode in your manual,that will automatically put the phone in it's normal operation mode.
In addition,you can as well switch it off and unplug it from the wall and also allow it to rest for about 5 minutes before you replug the socket back and switch it on.
wish you good luck,
TAKE CARE.
Posted on Jun 04, 2010
TD-1232 PBX - is is a programming issue or hardware issue?
ok so the first thing you should do is to get to where your PB X connects to the lines and ensure that there is a standing voltage on the lines. usually 50 v dc in the uk.
check each line has 50 volts with a multimeter when nthey are not active.
if line 3 has no voltage your problem is the line.
if line 3 does have voltage at 50 v idle ring the lines out 1 then 2 then 3 foir a analogue line to present ringing bthe voltage increases and is in cadence with the ringing. if again the voltage does not increase during the ringing cycle then the problemn is again with the line.
if the line 3 has 50 v idle and increase in voltage during ringing, then the problem is the line interface in the PBX
hope that this helps all above is for analogue lines only
Mar 10, 2017 | Panasonic Kx-td1232 Super Hybrid Pbx...
Do I have to dial 9-1 before the area code when faxing?
Hello, If you are in an office or corporate environment where the phone system is on a PBX you need to dial 9 usually to get outside the office. If you just have the unit setup at home or to an analog phone jack (not going thru a PBX) then just dial 1 + area code + number. If the number is local then don't use a 1, just the phone number and area code.
Chris
May 11, 2011 | Ricoh Aficio CL3500N Laser Printer
We have a Nortel Networks T24 phone with multiple lines on it and 2 of them are showing like it's in use but no one are using them. I will like to know if there's a way to cancel them.
This will usually happen if you either
1) Have not set disconnect supervision
2) Have telephone company lines that do not support disconnect supervision
3) Both
The easiest quick fix is to reboot the PBX.
The long term fix is to set disconnect supervision on the PBX for all of the lines and make sure that the lines form the phone company are set to provide disconnect supervision.
The exact way to set it up on the PBX varies by PBX.
Apr 12, 2011 | Nortel Networks NORTEL NT8B29 NORSTAR T24
We used to have a guy come in whenever we had phone problems but he retired. One of my co-workers somehow tried to transfer a person to one of our other locations but in the process have put lines 1 and 5...
When you transfer a call from the outside to an outside place, it will use two external lines for the duration of the call. Sounds like there the PBX is not configured for "disconnect supervision," (DS) meaning that it can't detect when the call finished on either side, so it holds those lines in use. Even if you set DS up on the PBX, the telephone company be sure the lines are programmed for COD (clear on disconnect).
If you do external transfers, you need to set up disconnect supervision on the PBX and COD from the telephone company.
This will probably involve the services of a professional, unless you are comfortable navigating the
internal menus of the PBX.
You can clear the lines by disconnecting the amphenol connector for the outside lines for a few seconds and reconnecting it (which will disconnect all outbound calls) or by rebooting the PBX.
Mar 21, 2011 | NorStar M7310 Corded Phone
Bell is ringing
This is not a telephone company. It is a help site. you neeed to be consulting the place you bought your PBX.
Oct 10, 2009 | Panasonic Toughbook CF-73 Notebook
Caller ID dOESN'T wORK
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Jul 06, 2009 | TalkSwitch CT.TS001.124001.US...
Cannot receive faxes
Faxes cannot be received but they can be sent Review the following information to determine why faxes are not being received.
  • Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, or Privacy Manager? These phone services are meant to prevent unwanted calls, but they will aslo stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  • If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  • If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Click here to go to the Drivers and Support page .
    2. Type in your model number (HP PSC 2210xi for example).
    3. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    4. On the software download page, select your operating system version.
    5. Locate and select the firmware update.
    6. Follow the directions to download and install the update
  • If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (buu04072) (in English).
  • If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (buu50333) (in English) to learn how to correct these problems.
  • If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or the problem cannot be determined section of this document.
Jun 24, 2009 | HP Officejet 4110 All-In-One InkJet...
External caller ID does not display on either line talkswitch 284
Click File> Save
Jun 18, 2009 | TalkSwitch CT.TS001.124001.US...
SAMSUNG DCS 12 OR 24 LCD HAVE (answer machine emulation)
Depends on your vmail system and telephone system. If you have a cadence vmail or svmi-8, you must go into system programming on your telephone system and program the key on the phone.
Jan 16, 2008 | Samsung Prostar DCS Phone
Lucent 960 corded telephone
I know this was posted 2 years ago, but I'll try to answer the questions anyway.
1) By itself, the AT&T 960 telephone does not have the ability to forward calls. That would be a function of your service provider (or in this case the PBX that it is connected to).
2) How to forward calls varies from PBX to PBX. You would need to speak with someone who administers the telephone system.
Aug 09, 2006 | Lucent AT&T 960 Corded Phone
127 people viewed this question
k24674
