Question about InFocus IN36 Projector
Projector blacks out after 5-7 minutes of being on
The projector will work for about 5 minutes after turned on and connected to dvd player but then will black out. it seems to be overheating, yet i put a fan over it to circulate air, and still the same problem occurs. Also, lines appear on the screen, subtle but almost as if from a bad connection or some type of interference.
    Guru:
  • 1,049 Answers
Check your air filter. These clog with dust and dirt over time and if obstructed will prevent even a good air flow from entering the projector.
Posted on Jun 04, 2010
No display from sony dvd player when connected to a projector
tried to hooked up your dvd player not in the projector, only in tv to ensure if it is working normally. if still the same problem might have a loose connection with in the dvd player.
Sep 02, 2012 | Televison & Video
Changed lamp and now turns on and only stays on for about 5 minutes and red lamp light stays on in an acer ph110 projector
Hi, what you need to do is reset the lamp hours to get the red light to go if it is a new lamp. To do that plug in a source such as a laptop or dvd player. When the display from the laptop or picture comes up go into the menu and reset the lamp hours I had the same problem. Hope this works if not let me know.
Nov 10, 2010 | Acer PH110 Multimedia Projector
Projector shuts off
try reseting the lamp timer and then replace the lamp if it works
May 05, 2010 | Planar PR3010 DLP Projector
Dell 1200MP works with PC but not the DVD player,
Hi.
If you have a replacement cable test the DVD using a different cable, you never know.
Try the following:
  • Unplug both projector and DVD from power.
  • Keep units connected together by video cable.
  • Connect back and restart the DVD first.
  • Restart the projector only once that DVD is ON.
If it still does not work , then there may be a fault.
Nov 09, 2009 | Dell 1200MP DLP Projector
I would like to connect my Sanyo PLV-Z2 project to a DVD player with HDMI output in order to higer quality. I used a HDMI->DVI cable and connected DVI to Z2. I set the input 2 as RGB-HDCP. However it does...
I have the same unit (2 of them actually.) I have spent a lot of time on this very issue. The problem is that although the unit is "supposed" to be HDCP (digital copy protection) compatible, it is not fully. I've found that with some DVD players it will work for a minute or two and then go black, and with others, it will flash on and off, and with some it will never do anything but black. I have only found 2 ways around this. 1 is to use a computer (which does not use the HDCP) windows Vista/windows7 might have the same problems, but XP/2000/Linux work perfectly. The other solution that worked was to use a Playstation3 which seems to work perfectly with it playing DVDs and BlueRays.
Feb 23, 2009 | Sanyo PLV-Z2 Multimedia Projector
Projector signal goes bad after 25 minutes
It appears the projector was over heating. Why it affected the DVD signal and not the computer signal, I do not know. The other confusing thing was the projector was hanging off the ceiling and should have had plenty of circulation. When I climbed up to check for excessive dust, I found that the lens cap had been placed over the intake vent. I blew off the dust and removed the cap. After running the projector for an hour, it appears that the problem has been solved.
Sep 22, 2008 | Dell 4100MP Multimedia Projector
Color problem
Check the cables connected to the back of the projector. reinsert the cables a few times to get a good contact. Jiggle the connection at the projector to see if there is a bad connection, do this while viewing the image on the screen. If everything is good and no response to the connections, It might be the main/input board is bad and will need replacement.
Aug 16, 2008 | BenQ PB6100 Multimedia Projector
Vertical lines moving from right to left at about 60 cycles
Probably solved long ago, but this sounds like RF interference. Is there a radio or television transmitting site within a few miles of your location? Or it could be the projector itself causing interference to the circuitry within the player yet not be a problem with any other source. Try it with another TV with the projector on and off. Even a small black and white will do.
Nov 11, 2007 | Pioneer DV-F07 DVD Player
Video then Black
the colorwheel is going bad and needs replacing.
Jul 27, 2007 | Dwin TransVision 3 Plus Multimedia...
DVD player - Picture goes from color to black and white
your problemens is in decodor of your tv its a proablem of service
May 06, 2007 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
InFocus IN36 Projector Logo
119 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
