Question about LG Flatron L2320A 23" LCD Monitor
No sound, other monitors have a input jack for sound but not this one.
  • LG Master
  • 32,281 Answers
Some monitors have built-in speakers and others do not have them.
In this case you need to purchase separate external speakers to connect into your computer. If your computer has audio output for surround sound, then you can buy 5.1 surround sound speakers. These will have 2 front speakers, 2 back speakers, a center speaker and a sub-woofer speaker..
Posted on Jun 04, 2010
MONITOR IS BLACK, POWER LITE IS ON, I CAN HEAR COMPUTER SOUNDS
By computer sounds do you mean the sound of fans and hard drives spinning? If there are no loud distinct beeps indicating a startup error (See Post Beep Codes), then I would check the following.
I'm assuming you mean the power light on the monitor is on. If that is the case then it is one of two things.
  1. The monitor is not set to the correct input source.
    • Make sure you go through the monitors menu and select the input. Example
  2. The video cable to the monitor has a bad connection.
    • Make sure the cable is connected properly
    • If repositioning the cable differently restores the image than the cable is most likely failing. Try replacing the cable with known good one.
    • If the cable is good it could be a problem in the jack on the monitor or the computer.
      To repair this would require disassembling the monitor or computer and replacing the jack.
      However, most computers and monitor have more than one type video input/output. Try the other input/output jacks. Example
Nov 16, 2013 | Impression Products Impression 9LSP 19"...
I cannot hear any sound from my Dell monitor 1702FP. Are there speakers installed within the monitor?. VGA cable is connected. When I use a spare monitor using the VGA cable the sound is loud and clear. ...
The Dell 1702FP doesn't have speakers.The specs of the Dell 1702FP are available here: http://support.dell.com/support/edocs/monitors/1702fp/en/specs.htm . (BTW neither does the Dell 1704FPT.) However, some Dell monitors can have a sound bar (speaker set-up) mounted on the monitor.
VGA cables don't carry sound. Check if a second cable (an audio patch cable is connected to the computer and the second monitor). (There are some cables that actually bundle the 3.5 mm patch cable with the video cable for convenience. (I've seen a number of DVI cables with that bundle option.) The plugs will separate into separate units at each end.
Other monitors do have speakers built in - look for a 3.5 mm audio input jack with the rest of the input connections on your monitor. There are some monitors that accept an HDMI input with a 3.5 mm audio out jack; these monitors don't have speakers and thus are enabling a daisy chain to connect the speakers to the monitor. So you do need to be careful and look for the audio in label.
You can attach a set of speakers to your computer using the audio out (look for a lime green 3.5 mm jack on the back of a desktop). For laptops or to use the front audio ports, look for a headphone jack.
I hope this helps. Please add a comment with more information about your monitor and computer for additional assistance.
Mar 11, 2012 | Computers & Internet
Dont know how to get the sound on, using the speakers implanted in the monitor.
You'll have to connect audio output (green jack on your motherboard/sound card) to the input on the monitor with a cable. You have not stated the model of your monitor, but usually the cable should have similar stereo audio jacks on both ends.
Sep 08, 2011 | LG Computers & Internet
I have a Samsung P2771hd monitor. I have green and black cords (for sound and microphone) coming from the computer. I bought a cable that has the black plug from the pc that splits to the red and white...
The Red (right channel) nand White (left channel) RCA plug to miniphone jack is made for audio amplifier with RCA input jacks. The monitor should have Green audio input mini stereo phone jack for the audio input from the PC audio line out (Green mini phone jack).
You will need the shielded audio cable with mini stereo phone plug at both end for the audio hook up.
Dec 21, 2010 | Samsung P2270HD 22" LCD Monitor
Have plugged a set of headphones into socket at back of monitor but nothing happens
Sockets at that place is not for head phones. That is for monitor sound. You have to connect that socket to the sound card audio jacks. In the new machines the sound card jacks are at the back of the CPU.
Nov 21, 2010 | Computers & Internet
Hi, I have a Samsung SyncMaster215tw, I've been using speakers to hear music and movies but recently gave them away, how can i get sound directly from the monitor?
The manual (you can download it here if you need a copy) shows an audio input jack right next to the VGA input connector. This jack takes a 1/8-inch stereo plug the same as the output jack on the computer. You can use the same cable that is usually supplied with computer speakers. Just plug the cable into the computer's sound output jack and the monitor input. I'd recommend setting the volume on the computer to maximum, and using the monitor volume control to adjust your sound.
Apr 01, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
No sound from monitor
You need to hook up an audio cable with mini stereo phone jack between the monitor audio input (Green jack) to the PC audio line out green jack. Both PC nad the monitor volume control will need to be set to your required level.
Mar 20, 2010 | Advueu Technology ADV178T 17" Flat Panel...
What is the sound card input on an hp2207?
The Jack which you found nearby the HDMi is a Input jack. you can get a output from your Computer's Audio out to to this input jack the speakers integrated with the moniter make sound. here there is no chance to plug your headphone. if you want you can plug your headphone in the front jack of your computer
Aug 25, 2009 | HP w2207 Monitor
Starlogic monitor - no sound
Did you plug in a sound input into your monitor? It will be a separate wire from the video input.
If it has a 3.5 mm stereo input jack then it probably has speakers, and you should connect that jack to the green headphone jack on your PC. If it has no input jack then it probably has no speakers.
Of course, the sound input might be included in the VGA cable, in which case that would divide near the PC with a green jack-plug on the end. Again, plug that into the green socket on your PC.
Sep 08, 2008 | Computers & Internet
ACER X191 Monitor - Speaker input?
go monitor back side and Saw of spk input point .input point name is line in .then insert the jack and connect ur pc lin out put point for Sound
Dec 13, 2007 | Acer X191WSD Monitor
LG Flatron L2320A 23" LCD Monitor Logo
539 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
