Question about Westinghouse LTV-19w6 Television
Want to install exterior speakers - Westinghouse LTV-19w6 Television
    Problem Solver:
  • 11 Answers
Go to menu, use ch. keys and click audio, use vol. keys to go to sub-menu, when sub-menu appears, use ch. key and click down to the tv speakers under heading "speakers", turn them "off". On left side in the back are the audio plugins, the top two under the s-video plugin, red on top, white next down are the two audio speakers rca jacks. Plug your external speakers, like the ones that you'd buy for a computer, in those two. The manual does not say if you plug speakers in these jacks the tv's builtin speakers will be cut off, but this tv I got was being used for a computer monitor and the tv's speakers were turned off from the menu, so I guess plugging in external speakers does not turn off the tv's speakers and would interfer with the external speakers. I suppose you could try it both ways and see, leave the tv's speakers "on" and plug in externals and see if they are turned off automatically.
Posted on Jun 10, 2010
I need instructions, written and hopefully with photo examples, that will teach me how to replace the passenger side mirror on my Ford Sport Trac. The truck is a 2004 model and the mirror is motorized...
Removal and Installation
NOTE: LH door is shown, RH door is similar.
  1. Disconnect the battery. For additional information, refer to Section 414-01.
  1. Remove the front door window control switch panel and trim covers.
    1. Remove the door screw cover.
    1. If equipped with power windows, remove the door window control switch and disconnect the electrical connectors.
    1. Remove the door handle bezel
3. Remove the door handle screws
  1. If not equipped with power windows, remove the screw and the window regulator handle.
  1. Remove the screws and the front door trim panel.
ganyapr_4.jpg6. Remove the door speaker Remove the screws.
Disconnect the electrical connector.
Remove the door speaker.
7. Disconnect the exterior rear view mirror electrical connector
8. Remove the nuts and the exterior rear view mirror.
Feed the power mirror wiring through the opening in the front door.
9. To install, reverse the removal procedure
i hope that this could help you
2010&c18=modelyear&c20=n712771&c35=wsm%2cfront%20door%20trim%20panel%2cs5r%2c501-05%2cremoval%20and%20installation&s=1280x800&c=32&j=1.3&v=y&k=y&bw=931&bh=469&ct=lan&hp=n&[aqe]
Feb 20, 2011 | Ford Explorer Sport Trac Cars & Trucks
2002 Mountaineer. How do you change the light bulb at the bottom of the driver side rear view mirror. Dan
SECTION 501-09: Rear View Mirrors 2002 Explorer/Mountaineer Workshop Manual REMOVAL AND INSTALLATION Exterior Mirror Glass Removal
NOTE: Exterior mirror glass is serviceable only on vehicles built after July of 2001.
NOTE: Passenger side exterior mirror shown, driver side exterior mirror similar.
All mirrors
  1. Position the glass in the full up position.
  1. Locate the notch at the bottom of the exterior mirror glass.
  1. Release the exterior mirror glass.
    1. Insert a long flat-bladed screwdriver in the notch.
    1. Push the screwdriver into the notch until the glass is released.
Heated mirrors
  1. Position aside the exterior mirror glass.
  1. Disconnect the electrical connectors.
All mirrors
  1. Remove the exterior mirror glass (17K707) passenger side or (17T675) driver side.
Installation
Heated mirrors
  1. Connect the electrical connectors.
All mirrors
  1. Position the exterior mirror glass on the exterior mirror motor.
  1. Place a hand against the back of the exterior mirror housing and a hand flat against the exterior mirror glass. Press the glass in place until fully seated.
Dec 26, 2009 | 2002 Mercury Mountaineer
Ford expedition side mirror (instalation giude)
SECTION 501-09: Rear View Mirrors 2003 Expedition/Navigator Workshop Manual REMOVAL AND INSTALLATION Exterior Mirror Removal and Installation
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
Front Door Trim Panel —Expedition Removal and Installation
NOTE: Left front door shown, right front similar.
  1. Remove the door handle bezel.
    • Use service notch.
  1. Remove the window control switch plate.
    • Use service notch and disconnect the electrical connectors.
  1. s3j~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
    Remove the two bolts and three screws, and remove the door trim panel.
  1. Remove the weather shield.
  1. Disconnect the exterior mirror electrical connector.
  1. Remove the exterior mirror.
    • Remove the nuts.
  1. To install, reverse the removal procedure.
    • Install top nut first.
Exterior Mirror Motor Removal and Installation
  1. Position the mirror glass to obtain a gap at the top edge of the mirror and carefully pull the top edge of the glass away from the mirror housing.
  1. Disconnect the heated mirror electrical connectors.
  1. Remove the exterior mirror motor screws and exterior mirror motor.
    • Disconnect the electrical connectors.
Oct 26, 2009 | 2003 Ford Expedition
How do I remove the left side mirrer on my 2000 ford explorer?
Mirror — Outside Rear View Removal
NOTE: Do not remove the exterior mirror assembly when repairing an individual part. Individual components can be installed without removing the exterior mirror.
  1. Disconnect the battery ground cable (14301).
  1. Remove the front door trim panel; refer to Section 501-05.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect the electrical connector.
  1. Remove the outside rear view mirror (17682).
    1. Disconnect the power mirror wiring clips.
    1. Remove the outside rear view mirror nuts.
    1. Remove the outside rear view mirror.
      • Feed the power mirror wiring through the opening in the front door (20124).
Installation
  1. NOTE: When the battery (10655) is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
May 29, 2009 | 2000 Ford Explorer
99 explorer drivers side mirror vibrates
are you trting to tighten the mirror glass or the mirror where it attaches to the body? I don't think glass is removable in 99. Only can try to press on glass to seat if unseated. not too hard.
  1. Remove the front door trim panel; refer to Section 501-05 .
  2. go to car-part.com for a used mirror. Page with * is cheapest seller.
SECTION 501-09: Rear View Mirrors 2001 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Glass, 2001 model Removal
All mirrors
Heated mirrors
All mirrors
Installation
Heated mirrors
All mirrors
Apr 12, 2009 | 1999 Ford Explorer
Replace driver side mirror on 2001 Nissan Quest
SECTION 501-09: Rear View Mirrors 2001 Villager Workshop Manual REMOVAL AND INSTALLATION Mirror —Exterior Rear View Removal
  1. Remove the upper speaker.
    1. Remove the bolts.
  1. Position the watershield aside.
  1. Remove the exterior rear view mirror access panel.
  1. Disconnect the exterior rear view mirror electrical connectors.
    • Release the wiring harness locator.
  1. Remove the exterior rear view mirror.
    • Remove the bolts.
    • Feed the wiring harness through the door opening.
Mar 31, 2009 | 2001 Nissan Quest
2006 ford focus driver side mirror (electric)
Not that hard on this model.Here is a pic of the mirror and the removal and installation proceedure.
http://i253.photobucket.com/albums/hh43/chuck943/N0025797.gif
  1. Remove the exterior mirror trim cover.
    1. Release the retaining clip.
    1. Disconnect the exterior mirror control switch electrical connector.
  1. Remove the exterior mirror bolt.
    • To install, tighten to 11 Nm (8 lb-ft).
  1. If equipped, remove the exterior mirror screw.
    • To install, tighten to 2 Nm (18 lb-in).
Mar 02, 2009 | 2001 Ford Focus
Side View Electric mirror can't adjust up enough for my height
You can manually push the mirror left or righ or up and down. It just ratchets on the plastic screw adjusters. It won't do any damage.
If you have floding mirros, make sure they are locked into position.
here's what inside looks like of 2002 mirror. I don't have 2005
SECTION 501-09: Rear View Mirrors 2002 Taurus/Sable Workshop Manual
All vehicles
  1. Remove the front door trim panel (23942). For additional information, refer to Section 501-05 .
Vehicles with Mach 40 speakers
  1. If equipped, remove the speaker grille.
  1. Remove the speaker bracket.
    • Disconnect the speaker electrical connector.
Vehicles with speaker delete panel
  1. Remove the speaker delete panel screw cover.
  1. Remove the speaker delete panel.
    1. Remove the panel.
All vehicles
  1. Disconnect the power exterior rear view mirror electrical connector.
  1. Position the water shield aside.
  1. Remove the power exterior rear view mirror nuts.
  1. Remove the power exterior rear view mirror.
    1. Push down on the mirror assembly to release the mirror flange.
    1. Roll the mirror assembly down and rearward.
Jan 21, 2009 | 2005 Ford Taurus
Replacement of Mirror/Assembly, 2004 Ford E350 Super Duty
NOTE: Aero mirror shown, dual arm similar.
Manual mirrors
  1. Remove the mirror sail cover to gain access to the exterior mirror retaining nuts.
Power exterior mirrors
  1. If equipped, remove the front door speaker.
  1. Remove the front door watershield.
All exterior mirrors
  1. Remove the rubber plugs and dust shield.
  1. Disconnect the electrical connector(s).
    1. Disconnect the power exterior mirror electrical connector.
    1. If equipped, disconnect the heated exterior mirror connector.
  1. Remove the nuts and remove the exterior mirror.
Jan 08, 2009 | 2007 Ford E-350 Super Duty Length XLT
How to remove mirror glass 2008 ford f350
here's 2003, don't have 2008
Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
Installation
  1. Remove the sealing boots from the exterior mirror motor.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn each jack pin until the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
  1. Align the friction pins vertically to the exterior mirror glass backing plate socket and push down to snap the pivot ball into the socket.
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
Nov 14, 2008 | 2008 Ford F-350
Westinghouse LTV-19w6 Television Logo
1,074 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
