Question about Garden
2005 Craftsman DYT 4000 18.5hp Briggs: As I was cutting I heard a whirling sound as if a belt was slipping on a pulley. The sound went away after a second or two, and then the deck began to vibrate. By that time I had shut the mower down. This occurred without hitting anything in the lawn. After examination, a pulley appeared to have loosened on top the mandrel. When I removed the top bolt I realized the bolt was not loose at all. The pulley itself was loose due to the grooves from the mandrel scoring a circle in the pulley where it is normally notched. Of course, the mandrel also had the notches round off in the corresponding area. When I dropped the deck and removed the belt, the blade and mandrel turned easily. I thought it would have been locked in place. After looking over the entire deck I noticed that the idler pulley spring was missing. Could this one little $2.00 spring have caused all of this damage? I can't find any other reason for it. Also, I have purchased two new heavy duty mandrel assemblies and a replacement pulley and spring. Are there torque specs for the mandrel housing bolts, and the mandrel top bolts? Should I use anti-seize or lock-tite in these areas? Thanks...
  • dcjohnson19 Jun 04, 2010
    Fairly generalized response. Would like more info on the pulley/spring problem, and the torque questions for replacement.
  • 416 Answers
DCJohnson, let me start by saying that the only thing you may want to put on the bolt would be a anti-weather, some of these come as anti seize, but it must be patroleum based. You definatly dont want lock tite in these areas due to the climate changes. This could prevent you from EVER getting that bolt out with a wrench again.
As for the tourque specs, the ft-lb specs really aren't that important, especially if you dont have a tourque wrench, which will guess you have. SO to get that out of the way, i would say roughy 35 ft-lbs of tourge would be fine. This is how i always judge my tourque by hand
1. Hand tighten the bolt until you feel your bicep working to turn it.
2. Then pull the wrench to you with the force equivillent to pulling yourself out of a chair or equivilant position. (typically 1/2 up to 1 full turn after reaching a tightened state.) you will know when its tight because you will here creeking sounds form the bolt. DOnt go more the 1 full turn if you do hear the sounds
GOOD LUCK AND PLS RATE THIS POST!!!!
Posted on Jun 04, 2010
    Great reply. I do have a torque wrench and have no problem with the 35 ft.lbs. Your advice about finger tight, hand tight, plus a couple of grunts, is a good starting point. Thanks. I'll make sure I use a non-petroleum based anti-seize or the equivalent thereof. I have heard that the mandrel housing bolts can be difficult to remove after they've been in awhile. Some penetrating fluid should be helpful with that.
    I still have a problem understanding what caused this mess in the first place. As I said, the mower didn't hit anything, but I guess the only thing that would shear off the teeth on the pulley would be the mandrel locking up. However, that would mean that the belt tension would be tight enough to continue to spin the pulley on top of the mandrel without spinning the mandrel itself. Could it be that the belt tension was too tight? If so, could the missing idler pulley spring create so much extra belt tension to actually spin the pulley without spinning the mandrell?
  • Remote Computer Rescue
    As for the damage to the mower and how it all started, from what I can tell it would be that spring you speak of. It sounds like this was a problem in the making. They belt engages the drive by being forced in the pulleys by that tention pully. The idea is you dont want a broken piece of equipment to default to being engaged. When it breaks, it is supposed to stop working for your safety and that of the machine. The whirling sound I am very familiar with as well, that is the sound of the drive pulley spinning without a belt touching it. It makes a whirling sound with a crips emphasis on the wh :)
    So all you have to do is replace that spring and make sure it is load correctly in relation to the drive lever. If you are trying to feed the belt behind the pulley, that would account for the seemingly broken pulley. I sure hopes this helps and feel free to elaborate if i missed anything
    Genius:
  • 1,040 Answers
Dear Friend,
Visit to the given link and see Best Solution,
http://www.fixya.com/support/t2288809-belt_adjustment
Putting devck belt on 48 inch cut craftsman DYT 4000
V part of the belt goes in the v pulleys. If the pulley is flat the back side of the belt goes against that. You don't need a diagram.
Jul 31, 2014 | Garden
I have a 2005 kia spectra and when i turn the ac on it is slipping real bad, what is it? I think it is the air conditioning clutch but i dont know for sure! it stops making the noise when i turn the ac off...
I had this problem, the belt was worn out and the bearings in the AC pulley are going bad. Removed the belt to the AC and the problem went away, no AC until I get the replacement.
Nov 25, 2010 | 2005 Kia Spectra
How do you remove an engine from a Craftsman dyt 4000 lawn tractor?
remove the deck and drive belt, then the pully and the four mounting bolts. unplugg all the wires and lift the motor out.
rural king has briggs and straton motors at their stores for a cheaper price than on line. I got a 18.5 hp for $420.
Jun 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Oct 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
The blades turn then stop on their own,is there an
Look for your model number under the seat. Sears website is www.searspartsdirect.com. It sounds like a bearing may be wearing out, or a spring on one of the brake arms is not holding the brake arms off the pulleys;
Or an idler pulley is not holding tension on the belt.
There is not adjustment I know of, just replacing worn parts. Hope this helps. Good day.
Apr 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
171 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
