Question about JVC AV-21meu 21" TV
I have a problem with my jvc av-21ca17b tv. the relay clicks 3x after that the red led fashing continously.
5 Suggested Answers
  • 1694 Answers
SOURCE: tv trouble shooting
1)Check secondary fuse devices. 2)Check horiz output xistor=shorted? 3)replace w/equiv.or better part. 4)Check solder connects in horiz drive circuit. Replace small electrolytic filter cap in base circuit of horiz o/p==horiz drive xformer and xistor area,typically 1mf/160v,C531? 2b)not shorted==do step 4 anyway 5)still blinking?==check vert o/p,audio o/p and regulated o/p's
Posted on Oct 02, 2007
joez47
  • 61 Answers
SOURCE: JVC AV-32F702 Color TV shuts off after I power it on.
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Posted on Sep 13, 2009
SOURCE: jvc big screen tv
Good day.
Please check for loose contacts along the cicuitry of your unit. Particularly on the system section.
Regards,
chris
Posted on Aug 18, 2008
  • 8457 Answers
SOURCE: JVC AV-K21T: TV goes off by itself
U know how to solder right?Take the backcover off take back of the handle screw driver taps where the part said it flickker or video back on, resolder that.
Posted on Sep 27, 2009
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Hi there TV is a JVC AV-36F713. Turned TV on a few days ago and nothing. Red flashing light on bottom of TV. Looked it up and manual said needs repair etc. Any ideas? Thanks Tim Also...
Hello Jim O'Connell,
Welcome and thank you for using FixYa!
To answer your question: I would suggest having a television repair professional pull out the power supply board.
They will need to remove the board and check it for bad (cold) soldier joints, bad capacitors, and lastly, to use an Osilliscope to test the +5v and -5V transistors on the board. If they can't diagnose the board, they can use the part number to order and install a replacement for you. That should fix your issue.
Have a great day!
Oct 15, 2011 | JVC AV-36D502 36" TV
Jvc- 36f702. Powers up then shuts down right away and the red led blinks on the front panel?
Dec 03, 2009 | JVC AV-36F702 36" TV
JVC model AV-27750 does not power up
Could be power supply failure
Jun 30, 2017 | JVC AV-27750 27" TV
TV 65'' JVC AV-65WP74
Defective power supply
Aug 14, 2017 | JVC Televison & Video
Jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Sep 25, 2008 | JVC AV-27020 TV
How to repair
check if it is plugged in,power button is pushed and standby led is lightening (red or green).
May 13, 2008 | JVC AV-27230 27" TV
TV wont power on, clicking noise and flashing standby led
Sounds pretty bad to me, I had a computer monitor that did a similar thing when plugged in after blowing, it's not a good thing. I didn't even bother to mess with it. You may have to replace the whole power board or at least have a whole handful of pieces to re-solder. It most likely isn't worth it unless your other tv's are under 30" and you don't have a lot of money ;)
- Dave
Dec 28, 2007 | JVC AV-32D305 32" TV
Televison & Video Logo
116 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
