Question about Kenmore 62802 Electric Dryer
My dryer wasn't getting hot so I checked it out and RAIN was sitting in the Vent line that lead outside. But, not it's not getting hot at ALL!!!!??????
    Sergeant:
  • 363 Answers
Since moisture has gotten inside the machine, it has probably shorted something out to control the element, or the element itself is shorted, or if it is gas, has the pilot light been extinguished?
Posted on Jun 04, 2010
  • 523 Answers
Are you sure its rain?when a dryer does not vent prop it can keep water in the vent hose so check/replace the vent
Posted on Jun 05, 2010
Dryer runs warm but never gets hot enough to dry fully
  • sounds like yo may have a restriction in your vent line. Check outside vent and see if you are getting a real good warm air flow coming out If not, check to be sure outside vent is not blocked and also see if the hose behind the dryer is kinked as that will cut down the ability for the dampness to escape out to the outside.
Jul 27, 2015 | Dryers
Why is water in the dryer vent line
There can be multiple reasons for this. If the vent line exhausts to the outside, it is possible that if the vent louvers are stuck open and rain may enter the line when windblown. More common is that dryer vent air is hot and moist due to the water being evaporated from the clothes. If the vent line runs through a cool/cold area, condensation may form in the vent line. If there are sags in the line, condensed water can accumulate in these places.
Sep 06, 2014 | Maytag MDE9700AYW Neptune 174 Electric...
Lg dryer check filter light wont stop blinking and the dryer wont work
You may have a clogged vent line.
Which will cause the check filter light to go on sometimes.
If the air is not getting out the vent and is blocked the sensor thinks the filter is clogged.
And you will not get heat either.
Check that the flexible vent line behind the dryer is not kinked or crushed.
A simple way to check if the vent line leading out from the dryer to the out side of the house is clogged is to remove the vent line from the rear of the dryer.
If the dryer gets hot when the vent line is removed, then the clog is between there and the outside vent door.
sometimes the little door outside the house gets stuck closed due to lint build up.
Or anything can be in the vent going into wall too.
Oct 20, 2012 | LG DLE2101W 7.3 cu. Ft. Ultra-Large...
My check filter light is on, the buzzer wont work but it is still drying
Hi
The electronic display on an LG dryer includes a "Check Filter" warning light. The light is primarily for convenience and does not indicate a major malfunction.
You may have a clogged vent line which will cause the check filter light to go on sometimes. If the air is not getting out the vent and is blocked the sensor thinks the filter is clogged. And you will not get heat either. Check that the flexible vent line behind the dryer is not kinked or crushed. A simple way to check if the vent line leading out from the dryer to the outside of the house is clogged is to remove the vent line from the rear of the dryer. If the dryer gets hot when the vent line is removed, then the clog is between there and the outside vent door. sometimes the little door outside the house gets stuck closed due to lint build up. Or anything can be in the vent going into wall too.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 02, 2011 | LG DLE2516 Electric Dryer
We have question to ask you for Miele Laundry dryer model T4804 C. Our client will install this model in the apartments. They suggest us to connect Dryer vent pipe to the main kitchen exhaust duct of the...
if you use the kitchen exhaust it will ruin the kitchen ducts and forse flow hot air and lint onto the range hood into the kitchen . . stupid advise .. it needs to be ducted directly through the wall to outside using a rain gard the temp can get as high as 47 degrees hot but not too hot it forses air out at a ratio of aprox 15 psi
merry christmas
Dec 22, 2010 | Dryers
When I turn on the dryer, the top gets VERY hot within about 2 minutes. When I look inside, you can see the heating element is red. I checked the vent and it is clear. I did notice that there was some...
if the lint is damp then the air isn't moving out the vent line,unplug the dryer, go outside and make sure the hood is clear, then go back inside and remove the vent line from the back of the dryer,if the vent line is long i use a leaf blower to blow out the line,just stick it into the vent line and blow it so all the lint will go outside,if you could have someone watch the outside and they can let you know when the line is clear,also the duct that the lint filter slides into should be cleaned out and you should vacuum out where the motor is,you have an open flame inside the dryer and the lint can and will catch fire if it's not cleaned out,i do this to my dryer once a year,the clothes dry on time,no fires and the parts in the dryer last longer from being cleaned and the dryer isn't overheating and damaging the motor and other parts from running to hot.let me know how you make out
Oct 29, 2010 | GE DVLR223 Dryers
Dryer is hot to the touch after cycling off
If its the top of the dryer then the problem is with your venting. Run the dryer and go outside check to see if you have any airflow. If you dont feel strong airflow then replace or clean your vent line. This can lead to blown hi limit fuses if the problem is not corrected.
Hope this helps _MJ_
Jan 29, 2010 | GE Dryers
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
When it gets hot it stop and then start again when cooled down
This problem is usually caused from restrictions in the vent hose and the unit getting to hot causing the limit control to shut down until it cools. Check your filter, your dryer vent line for obstructions and the outside for pieces of lint plugging it and slowing the air flow. I have found lint build up in the line, at the base of the dryer where the exhaust line connects, and in the exhaust mounted on the outside wall.
Oct 09, 2009 | Kenmore 63942 Dryer
Kenmore 62802 Electric Dryer Logo
260 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
