Question about LG 24 in. LDF7810 Built-in Dishwasher
D. Washer drains & fills stop thin flasses LE code?
  • 523 Answers
The motor is bad
Posted on Jun 04, 2010
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Lg washer fills, starts to wash but stops
have you checked brushes on motor
Jan 27, 2014 | LG Washing Machines
LE error cam e on and I've drained the water, cleaned the filter, etc. I also unplugged it to reset it. It fills the water and starts to spin, but it suddenly stops and gives me the LE error once again...
If your washer is an LG (unfortunately you have not said) on most 'LE' stands for 'Lock Error'. If so there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent with the extra movement of spinning, requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 29, 2011 | Washing Machines
Cycle stops and the code FE appears and to refer to manual but I don't have one, can you help
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
Must be some sediment in the water level pressure hose. Blow out the sediment, reconnect the hos, pump out the water and retry. This is an lg washer. You may only need to set or reset the water level frequency. I have service manuals and notes HERE
Apr 06, 2011 | Washing Machines
Washer starts to fill then stops /now warsher wont wash
I too was having the same problem and I almost paid to have it repaired, which would have cost a few hundred dollars, thanfully I called the recall line after reading some of the other post on here and my machine was elgible for a upgraded on the control panel so didn' t cost anything for us. Sears told us that the F1 code is a miscommunication in the control panel, basically the machine is confused and don't know what to do so it stops and gives that code. Hope it helps!
Jun 19, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Le error code
IE means that it is taking too long to fill up.
May 28, 2009 | LG WM-0532HW Front Load Washer
Washer stops after fill
You should control the pressure switch on the machine. It is a circular object on the top of the machine, and it is connected to the drum with a thin hose. Remove the hose from drum and blow the the hose, you shuld hear 2 or 3 ticking sound from the switch. If you can not hear, change it with a new one. Also clean the thin hose, it can be blocked by detergent.
May 28, 2009 | Kenmore Washing Machines
Error code LE and OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Apr 12, 2009 | LG LDF8812 Stainless Steel Built-in...
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
Dishwashers Logo
85 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
