Question about Samsung FPT5084 50 in. Plasma HDTV
My samsun fp-t5084 is making a loud whining noise
My samsung fp-t5084 is making a loud whining noise from the processor on the left side what could cause this?
  • 416 Answers
Its either a fan going out or power transformer. take the panel off and turn on the unit while being careful not to touch anything at all while power is to the device. plug it in and listen so you can identify the component. If its a transformer (it would more than likely be square and wrapped in a thick polymer sheeting.) it will be fine, possible for good. If its the fan making noise, you will typically have 9-12mths from the time you first here the sound before the perfomance is affected.
SO, to make a long story short, a hummming sound is typically the sound of electrical variations in a component, whining is normally a rubbing action within metal and plastic components.
(plastic on plastic makes a squeek, metal on metal a higher pitched squeek)
Posted on Jun 04, 2010
I need a Repair/parts manuals for Samsung Plasma, Model FP-T5084
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 18, 2015 | Samsung Televison & Video
How to fix loud whine from gigabyte ga-f2a55m motherboard
This particular main board doesn't have the video integrated into the mobo, so it's got a video card. Often the video card has a fan. The fan could be causing the noise. Have you tried briefly unplugging the processor fan to see if the noise stops?
Apr 23, 2014 | Gigabyte GA-F2A55M-DS2 Micro ATX AMD...
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Samsung fp-t5084 fuse fix is the replacement fuse slow burn or fast burn?
I'm certain it uses a T12amp slow blow type. I have the exact same model, you can replace the fuse. The TV will for a while, but that fuse will blow again. You will need to replace the power supply board for a more permanent fix.
Dec 21, 2012 | Samsung FPT5084 50 in. Plasma HDTV
My Samsung FPT5084 50 Inch Plasma TV....keeps turning itself on and off. Does a solution exist to my problem. I am out of warranty,
http://www.retrevo.com/support/Samsung-FP-T5084-TVs-manual/id/2839bh444/t/2/
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010200&prd_mdl_cd=&prd_mdl_name=FP-T5084
Below is the service manual link from epox. ftp://ftp.epox.com/downloads/Manual/mu-8KDA3J&+11.pdf
This is usually a switchmode power supply problem, and it's shutting down, for safety reasons, so as to avoid a fire and explosion or both. Realistically you need to get a "Quote" from an authorised service agent, for repair.
May 24, 2010 | Samsung FPT5084 50 in. Plasma HDTV
Loud Whining Noise from Motherboard on Startup
Whining noise is something in motion or moving.Does the graphics card have a onboard fan?Is it clean and free moving.
How about the processor fan? clean,free from wires or anything hitting it.?
Disconnect hard drive and see if you get the sound.
Jan 18, 2010 | Abit IP35P Motherboard
Samsung FP-T5084 No picture
For a 50 inch plasma....its worth it, in my opinion y-boards cost around $149 to $189
Nov 03, 2009 | Samsung FPT5084 50 in. Plasma HDTV
No power to Samsung FP-T5084
I had the same problem twice with my Samsung FPT 5084 and it was the 12 AMP fuse on the power board both times. The bad part is you have to remove the whole back plate to get to it but once off it sits on the power board (dead center) towards the lower left hand side of it. Replace the top fuse or you can replace both. They're just regular ceramic sealed 12 AMP fuses that cost about 50 cents each.
Jan 22, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Samsung FPT5084 50 in. Plasma HDTV Logo
256 people viewed this question
Jerry Greenberg
Jerry Greenberg
