Question about Hitachi 46F510 46" Projection HDTV
Samsung sp42w4hb Rear projection
In the top left hand part of the screen the colours are not matching up in a sort of wave but the other part of the screen is perfect. please help
  • vik_mickey Aug 02, 2008
    i have the same problem. in the left corner the colours dont match up. its all doubled. and when i do perfect focus it cuts off at 22%.
    how do i fix this?
  • 80 Answers
Needs new convergence ships, part number stk 392-040, there is 2 of them, replace them both, also check fuses on the board, you probably need a tv repairman to fix this.
Posted on Sep 05, 2009
Samsung le26r51bd picture loss.
it is problem your tv high voltage (EHT) not properly supply or creats high voltage
Nov 22, 2009 | RCA D52W19 52" Rear Projection Television
LG rear projection colours out of alignment
I have a similar problem with an LG (except my red is the one that is fine) and was able to talk to a tech in some detail about it. The tech prefaced by saying that he had done a hundred or so of these with exactly the same issue. This is very common and the life span of rear projection televisions is not great. Having said that, plasmas and LCDs are also limited in life span mostly due to modern high performance gaming machines which shorten the lifespan of monitors both plasma and LCD alike.
From what I have gathered, this is not a problem that you can easliy sort out. (Of course they would say that though) It involves replacing the digital board which means soldering followed by aligning the lamps which requires quote a lot of expertise.
The part itself apparently costs around $200 Australian and the labour will vary for the cost of the technician but I was quoted that the labour was about the same cost as the part.
Not sure if I would call this solved but I hope it has been at least a little helpful.
May 26, 2009 | JVC AV-56P575 56" Rear Projection...
Distorted colour
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 07, 2009 | Hitachi 50UX57B 50" Rear Projection...
Colours serparated, not converged, screen looks concave
Replace Both fo your STKs convergence ICs STK392-040s. For Parts Call 1-800-223-3205
Dec 30, 2008 | Samsung HC-P4741W 47" Rear Projection...
Samsung tv SP42W4HB fails t power on!Please help!
Typically a convergence amp fails and causes the shutdown. There are two to handle the job so when one goes both should be replaced. This failure may also damage associated fuses and resistors.
Nov 06, 2008 | Televison & Video
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
How to repair a samsung rear projection tv
your power supply is getting weak
Aug 25, 2008 | Televison & Video
MODEL NO SP42W4HB PICTURE DISTORTED TOP AND RIGHT SIDE COLOURED SHADOWS COLOURED WAVY LINES TOP THIRD SCREEN PINK AND GREEN
This is most likely a convergence problem. You should see 2 large black ICs in side attached to a heatsink. They will be marked STK392-010. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace them. These parts will be about $20 each.
Keep us posted.
Dan
May 28, 2008 | Samsung Televison & Video
Samsung rear projection tv sp42w4hb
I would check the CRT socket module for Cracked solder joints. If not you may be in the early stages of the CRT shorting, If so you will need a new CRT.
Jan 04, 2008 | Televison & Video
This is all i could find when i did a search:
they have inherent problems with the glycol oil used to cool the tube leaking past the bladders & onto the boards.... & it's conductive :p
Dec 10, 2007 | Televison & Video
Hitachi 46F510 46" Projection HDTV Logo
198 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
