I have a Teac A-1250 Stereo Tape Deck. When I try to play or record, the capstan will not engage to move the tape, it moves by the take up reel pul1ing the tape through. And the tape is still held away from the heads,
  • gekase Jun 09, 2010
    Thanks, but that is not the problem. The belt is fairly new, and is still flexible. The pinch roller will not engage the capstan, will not energize.
  • Anonymous Mar 17, 2014
    national panasonic stereo tape deck 269
  • Audio Player... Master
  • 1,267 Answers
More likely is the need to have the Pinch Roller linkage cleaned and greased. The capstan belt can be an issue but they surprisingly have lasted this long many times. They are stretched from over the years but not to specs- I would replace all belts in the deck and do a lot of other maintenance as well. I bet the Pinch Roller is gummed up- they usually are due to the grease they used. I know these machines as I am a past Teac Technician from Chicago Factory Service- I now operate Skywave Tape Deck Repair.
Posted on Apr 12, 2015
    Champion:
  • 222 Answers
Replade the capstan belt you can buy it @ partstore.com
Posted on Jun 06, 2010
  • Doldog Jun 09, 2010
    There are two types of belt, one is for a capstan belt and one is for your threading belt, make sure they're both in good condition.
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
Sep 18, 2017 | Teac Audio Players & Recorders
I have a teac 2300s tape deck. My problem is when i press the rec / pause or rec play the 2 meters slam to the right. They don't move while recording,but the deck will record and playback. Putting the...
The leads to the VU meters have shorted out. The fact that it only happens when you push "Record" sounds like part of the mechanism is actually causing the short.
Jul 15, 2017 | Pioneer Rt-1011l Reel To Reel Tape Deck...
Teac a-3440 will not play
Hi Gary,
This makes me think the Capstan Shaft is not turning either due to a broken or stretched belt or that the capstan motor itself has stopped working. This may be a job for a Technician. You first determine if the Capstan is turning or not- this is the metal post that contacts the Pinch Roller that rotates and is the way the deck gets it's speed regulation. If it is not turning look inside the deck from the side to see if the flywheel is turning and that the belt is on that flywheel. Lastly make sure the capstan motor is turning.
Beyond that a Tech may have to take over from there. I am in the Chicago area and can repair it if you are close. Many people send me units from all over the USA anyway.
My name is Sam. I operate Skywave Tape Deck Repair
skywavebe@sbcglobal.net if you need my help.
Aug 17, 2012 | Teac Audio Players & Recorders
I have a TEAC W-450R Stereo Double Reverse Cassette Deck. For some reason, the REC/PLAY II side will not operate. It has not for some time. In fact, that is why I believe I mothballed it some years ago....
I have not seen those to a large extent due to their value not being worth a repair. I did work on them at Teac though. The capstan motor of the right side deck sound like it is burned out. I have some motors here so it is just a matter of if you want me to work on it or not. I get a lot of units in all the time- I am Skywave Tape Deck Repair in Chicago area.
Feb 22, 2011 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
My Teac 4070G reel to reel tape deck rewind and fast forward functions work, but the play function does not. Any ideas? Could it be a circuit?
Without actually seeing your Teac reel deck, i suggest you verify that all fuzes in the deck are good..not blown. Also with a tape correctly installed..ensure that left and right tape tension arms are held under tension/ closed by tape tension, also ensure the capstan shaft is rotating... look in back to ensure the capstan drive motor is running.. if yes, and tape still will not play... problem could be a stuck/failed solenoid, dirty or corroded push buttons, or corrosion on contacts where rear circuit boards/plugs insert into other boards.
Feb 28, 2010 | Audio Players & Recorders
Does this recorder have its own amplifier?
Sure, the tape will play.
Copying tapes does not require an external amp, but LISTENING to them might. The A-4010 has a headphone jack so you're good to go with headphones alone if necessary.
To record, Connect the Output from the new deck to any Line Level Input on your recording device - (NOT PHONO).
If you can, set your record levels up in advance being careful not to have them too high if you're going digital as overloads are not handled well.
As with any old, rare or prized open-reel recording, avoid excessive transport handling of the tape, especially rewinding at high speed. Get yourself some Q-tips and isopropyl alcohol and clean the deck carefully, especially the capstan and idler wheel. Cheat the two tension levers manually and press Play. The capstan will engage the rubber idler. Clean the roller first with a moist Q-tip, being careful not to get strands caught up in the capstan (I'd hold the Q-tip around the 3-o'clock position on the idler), until you get nothing but a little black from it on a clean moist Q-tip. Then press Pause and the roller will retract but the capstan will still spin. Clean it with a fresh wet Q-tip until it is shiny and no more color comes off it.
Handle the reel without placing any inward pressure on the flanges as edge damage can occur.
Make your best stab at a transfer in as few tries as possible as the tape oxide and base are very old and will not tolerate repeated playbacks. Run the tape completely in one direction, flip it over, CLEAN THE DECK AGAIN, and play it back in the other direction (avoiding REWIND as it places a lot of stress on the tape and will probably leave the tape wound unevenly with edges sticking out all over the place. A normal speed playback should wrap the tape nice and tight and even for storage. Avoid exposing the tape to high humidity, dust or heat.
If you have access to a CD Recorder, I recommend making a full resolution Master copy on it and using the digital copy for any subsequent copying, ripping, editting, etc. Archive the original tape and make a digital copy of your end results, too. Good luck.
I'll make this offer to you. If you get it digitized and onto a CD I can probably reprocess it to clean up tape hiss and other problems inherent in 70's-era taping. Analog tape recording was my passion and still is, but I save everything digitally now.
Apr 26, 2009 | Audio Players & Recorders
TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it bigmattt@gmail.com
Nov 24, 2007 | Audio Players & Recorders
549 people viewed this question
 Grubhead
Grubhead
