Question about Sony Playstation 3 (PS3) Console
Screen keeps flashing. I have switched the HDMI cable and it still does this, Is this a comon problem?
  • 370 Answers
No but what is happening is the Hz that the PS3 is putting out is more than the TV you have it hooked to will take, go to your menu screen and find the screen settings and bring the Hz down to a level that the TV can handle, also try a different Resolution that will help also...
Posted on Jun 04, 2010
Can't accept my hdmi cable via laptop, keeps saying no signal
Are you enabling the external display feature? The HDMI must be enabled from the laptop keyboard before it will output. This is done with the "Fn" Key (lower left next to Windows key + the F5 key. This is a 3-way toggle. The default is normal screen. First toggle switches to external (HDMI), second toggle to both screens, and the third back to normal.
This excerpt from your User's Guide:
<Fn> + <F5> Display toggle
Switches display output between the display screen,
external monitor (if connected) and both.
Nov 27, 2015 | Televison & Video
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
When I switch my tv to the HDMI input it appears to be normal for a few seconds but the screen stays black and I get a thin pink line running horizontally across the bottom right corner of the screen then...
You did not mention what you are connecting with HDMI but I have had problems with my PS3 and it is copy protection related. On a PS3, you have to connect it to HDMI1 otherwise some BlurRay movies will not play.
You might have a bad HDMI cable. I have heard the quality of cable does not matter these days but I still have had issues with the really cheap cables. I still do not buy the really expensive HDMI cables though.
Aug 29, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
The TV turns on but cannot find a signal (as has been normal when swictching to HDMI inputs). Usually it takes a second and the Cable or FIOS signal shows on screen. As of today, the images never comes...
Tries tv and cables boxes uplug,replug it back like about an hour later for the tv resetting itself back to the factory setting and those pay boxes updated it softwares.Take the HDMI cable plug it in into another tv HDMI hub.Tv should have signal and work again.
Feb 17, 2011 | InFocus ScreenPlay 61" Rear Projection...
When the hdmi cable is plugged in the screen become black and it flashes off and on!
TRY A NEW HDMI CABLE, SOME NEW TV'S REQUIRE 3.1 HDMI CABLE MAKE SURE IT IS THE RIGHT VERSION, THE SOURCE COULD ALSO BE THE PROBLEM, WHAT IS THE CABLE PLUGGED INTO, ECT... CABLE BOX, DVD PLAYER ANS SO ON, SWITCH CABLES AND SOURCES TO ELIMINATE ALL POSSIBLE PROBLEMS
Dec 30, 2009 | JVC HD-61Z456 Television
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Dec 01, 2009 | Televison & Video
PS3 screen flash / sound cut-out
The PS3 has an issue with what's called the "HDMI handshake" between the PS3 and the TV. The PS3 does not even realise that this is happening. What you might try to do is turn the system on, play a game, and when the flashing and no sound occurs, unplug the HDMI cable from your PS3, wait a few seconds and plug it back in. This may resolve your issue. If it doesn't work, try component cables, there is no known issue with this problem occuring with this type of connection. Good luck!
Aug 20, 2009 | Video Game Consoles & Games
Flashing / ghosting with Bose Lifestyle V30
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues. Component cabling from your devices should eliminate your problems.
I hope that helps.
____________________________________________
Download Bose LifeStyle V30 User Manual
Mar 15, 2009 | Bose Lifestyle V30 Home Theater System -...
Xbox 360 elite won't play any games
Did you try to see if your tv's hdmi/component cable input(s) are working properly? Try another device to see if it works. Then check your cables and make sure all of them are pluged in at the right place and securely in. If it still doesn't work, then contact Microsoft because it's an internal error. Also it wouldn't hurt to unplug everything from the 360 and repluging it. Microsoft always says that as a first troubleshoot.
Mar 14, 2009 | Microsoft Xbox 360 Elite Console
Picture flashes
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Oct 18, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
380 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
