Question about Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher
Fisher & Paykel Q 2 drawer dishwasher, comes on randomly, sounds like washing, but no water and beeps. Also, is there a manual online which I can download?
reg501
  • 413 Answers
SOURCE: How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
When a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
There are three possible scenarios;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
OR
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
If you need further assistance, let me know
reg501
The FixYa Team.....
Posted on Jun 23, 2008
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Posted on Mar 13, 2009
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
  • 81 Answers
SOURCE: reset fisher and paykel two drawer dishwasher
Have you tried turning it off and on at the power point?
Mat
Posted on Sep 24, 2009
  • 784 Answers
SOURCE: How can I empty some residue water from the Fisher
Go to diagnostic mode you can turn on the drain manually. The motor has 2 directions of operating: one for pump and the other for drain. When the LCD displays P1 it means wash, when it displays P2 it is for drain.
Posted on Nov 01, 2009
Fisher paykel dishdrawer bottom drawer washes fine leaves water in top drawer
At some point the two drawers individual drain hoses are joined using a "Y' type connector. Check this, and everything beyond this point for restrictions or blockage. It sounds like the bottom drawer is pumping its drain water out normally, but some of that water is backing up to the upper drawer. This is an installation or plumbing problem that is external of the dishdrawers.
Jul 25, 2016 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
http://applianceassistant.com/ServiceManuals/dishwasher-fisher-paykel-dish-drawer-dd603-ds603-service.pdf#zoom=100#scrollbar=1
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher & Paykel DD24DCTB6 top drawer beeps instead of starting
It is very likely the two problems are not linked. Use small quantities of power detergent (Finish works best) to avoid foaming. The foaming usually triggers flood switch and shuts dishwasher. If the beeping is constant then most likely the flood switch is triggered. But if you get one or 2 beeps when you press start, then it is likely some sensor in drawer is faulty. Usually the drawer close switch is not working.
Mar 18, 2013 | Fisher and Paykel Dishwashers
F & P DD603 starts to wash then beeps & flashes U1 - Fill Fault. I have cleaned both drawers & replaced all parts correctly, still comes up with U1.
Have you checked whether you are getting the water supply to the dishwasher. Check if there is no kink in the water hose.
If no problem with water supply then check the water pressure rating is OK for the dishwasher.
Dec 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
F 1 Error, blinking, beeping and will not stop even when turned off, so we had to turn the circuit breaker off to stop the noise.
You have a leak.
Either from the top lid seal or bottom lid seal. A s time goes by the water level activates the sensor causing the beep. It won't do anything until you fix the leak.
May 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
