Question about GE Security Simon 3 Wireless Home Security System
I ran my Simon 3 without AC for a couple of days, and the no-load battery voltage went down to 4 volts. The no-load voltage has trickled back up to 6 volts, but I still get the alarm. How do I turn off the alarm?
  • russvan Aug 23, 2010
    Are you getting a low battery alarm or a burglar alarm activation? Alarmprofessor.net
    New Friend:
  • 74 Answers
You need to replace the battery.
Alarmprofessor.com
Posted on Sep 05, 2010
KUN 26 D4D Hilux...something is draining the battery over 3 or 4 days...Alternater putting in 13.85v but battery goes flat over 4-5 days
13.85 volts is barely sufficient and would indicate an alternator fault if the reading was taken "off-load"..
An alternator is not designed to charge the battery and is incapable of doing so because the terminal voltage of the battery quickly rises to fool the voltage regulator into believing even a discharged battery is fully charged and will quickly reduce the charge rate to a trickle.
The alternator is therefore designed to keep a fully charged battery fully charged by supplying all the current for the vehicle equipment and the output rating is chosen for this purpose.
The voltage regulator should limit the off-load voltage to about 14.5 volts but that is only a small part of the alternator test. A professional would apply a load across the battery equal to the rated output while monitoring the voltage and current. Most healthy alternators exceed specifications.
For a sensible in-service test when an adjustable load isn't available, with a fully-charged battery it is sufficient to start the engine, leaving it to idle and switch on all the vehicle equipment. Fit a voltmeter to the battery and wait while the battery voltage is pulled down by the load - to around 12.5 volts. Raising the engine speed to 2500/3000 rpm should cause the voltmeter to suddenly rise.
13.85 would be just about acceptable "on-load" but in excess of 14.0 volts would be ideal.
Jul 10, 2016 | Cars & Trucks
Wiring harness location
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Jan 28, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
Battery meter is reading low 11's when running. I ride the bike at least 3times a week. Couldn't start it a couple of days in the last two weeks without plugging in the trickle charger. Lights...
Hi, Anonymous in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
1. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
2. Check the voltage drop at the battery when you hit the starter button, anything below 9 volts you might have a faulty battery.
3. Check voltage at the battery with the bike running at 3,600 RPM should be 14.3 to 14.7 volts. If you are not getting these numbers, you might have a faulty voltage regulator.
4. Make sure voltage regulator is grounded and functioning properly, watch the video below on how to test a voltage regulator.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the meter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers, you may have a faulty rotor, follow step 6
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to a ground, the meter should read infinity. Connect both leads to the alternator meter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers, you have a bad stator.
7. Check all wiring in the charging circuit for worn or chaffed spots and all wiring connectors in the circuit for corroded, broken, or loose pins/sockets, which is the # 1 offender.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.ducatimonster.org/forums/tech/227745-help-needed-w-3-phase-charging-system-diagnosis.html
http://www.dotheton.com/forum/index.php?topic=48646.0
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Feb 20, 2013 | 2008 Ducati Monster 696
Battery won't hold a charge
Hi Rick, perform the following tests:
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
3. Make sure all connections are clean and tight especially the negative cable at "BOTH" ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
17. For a free wiring diagram please visit the website below. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Apr 14, 2012 | 2007 Harley Davidson FXD Dyna Superglide
I have a 1996 fzr 600 , it shut off going down the road , went to start bile. But batt was completely dead , pushed it off it ran for about a mile or two n died , bike is not charging at all could this be...
Hi, Jporzio82 in order to check out any main system electrical circuit, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
4. Make sure voltage regulator is "GROUNDED" and functioning properly, watch the video below on how to test a voltage regulator.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
battery not charging The FZR Forum
FZR600 generator charging issues
https://www.tradebit.com/filedetail.php/2864660-yamaha-fzr-600-service-repair-manual-pdf
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Apr 04, 2012 | 1995 Yamaha FZR 600
Driving down the road on my '02 V star 1100 my headlights are flickering at night. Then the speedometer and odometers both went out. The bike ran for about four more miles and then sputtered and...
Hi, Pitts08 in order to check out any main electrical system, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the multimeter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers, you may have a faulty rotor, follow step 6
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to a ground, the multimeter should read infinity. Connect both leads to the alternator multimeter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers, you have a bad stator.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
How to diagnose and repair motorcycle charging problems
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Jun 07, 2011 | 2002 Yamaha V Star 1100 Classic
I have a 1995 Jeep Grand Cherokee with a 4 month old battery.A couple of the power door locks quit working a while back and my husband went out a couple of days ago and sprayed them with WD 40 but they...
check the voltage on the battery with a volt meter, it should be around 12.6 to 13 volts, if not charge battery with a charger, after charge try to start vehicle, if the vehicle starts use your volt meter at the battery again, the voltage should be around 14 to 14.5 any lower and the battery isn't being charged and the alternator should be checked and or replaced to solve the problem..
Feb 28, 2011 | 1995 Jeep Grand Cherokee
I have a Simon XT which I installed about two weeks ago. I keep getting a system low battery message when I press the status button on the console. I had a new battery shipped and I installed it about 24...
Call your Central Station and put your account on test if it is a monitored system.
Power down the system. Disconnect the battery, then the AC adapter. Then plug the battery in first, then the AC adapter. Plugging the AC adapter in first can cause the low battery message.
if that doesn't work, with the battery disconnected, measure the voltage of the battery with a multimeter. If it reads less than 5.4 volts, the battery is bad. Bad out of the box batteries are not too uncommon.
Next, check the charging voltage from the panel. Measure DC voltage from the leads that connect to the battery. They should read around 6 Volts DC. If the charging circuit is bad, it will cause a low battery trouble and the console will need to be repaired or replaced.
Hope this helps.
Feb 19, 2011 | GE Security Simon 3 Wireless Home Security...
Simon 3 system not charing battery. Only .26 volts on terminals on the mother board. Does system have a fuse. I installed another new battery and it lost voltage by the next day so with the low voltage it...
There is no fuse on the Simon 3 board. If your transformer is good and measures 9-11V AC you charging circuit is gone and you will need a new motherboard. AlarmProfessor.net
Aug 13, 2010 | GE Security Simon 3 Wireless Home Security...
Simon 3 Wrong Voice Prompts...
check both the batterys voltage and that of the transformer for the corect voltages. a good 12 volt battery should read above 13 volts also check the charging voltage to your battiery by disconnecting one leg of the battery and see what you read across the read and black leads. it sounds like a power problem.
mj
mj
Jul 29, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
112 people viewed this question
Top GE Home Security Experts
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
